08-19-2008, 07:53 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| battery charge question
just got this battery http://www.horizonhobby.com/Products...rodID=ORI10308 and I have a pirahna digital charger. What should I set the max vm/c to for charging that battery and what amp should I charge it at? |
08-19-2008, 08:24 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
I never really change the VM/C when charging a battery. The rule with batteries is don't charge a battery at more than its rated mah. Here is a small chart I put together. MAH Amp 100... 0.1 200... 0.2 300... 0.3 400... 0.4 500... 0.5 600... 0.6 700... 0.7 800... 0.8 900... 0.9 1000... 1.0 1100... 1.1 1200... 1.2 1300... 1.3 1400... 1.4 1500... 1.5 1600... 1.6 1700... 1.7 1800... 1.8 1900... 1.9 2000... 2.0 2100... 2.1 2200... 2.2 2300... 2.3 2400... 2.4 2500... 2.5 2600... 2.6 2700... 2.7 2800... 2.8 2900... 2.9 3000... 3.0 3100... 3.1 3200... 3.2 3300... 3.3 3400... 3.4 3500... 3.5 3600... 3.6 3700... 3.7 3800... 3.8 3900... 3.9 4000... 4.0 4100... 4.1 4200... 4.2 4300... 4.3 4400... 4.4 4500... 4.5 4600... 4.6 4700... 4.7 4800... 4.8 4900... 4.9 5000... 5.0 Last edited by Shaun; 08-19-2008 at 08:27 PM. |
08-19-2008, 08:31 PM | #3 |
that makes sense is that about all there is to know? I left the mv/c at the numbers that was on the charger, like 12.5 or something
08-19-2008, 08:59 PM | #4 |
Well other than a few other things. If its LIPO and more than one cell, make sure you balance it, don't run the battery all the way down, or it will ruin it. If its NICD, make sure you run it down all the way before charging it again or it will keep a "memory" If its NIMH, have fun with it, recharge it when ever, and run it down all the way if you want. |
08-19-2008, 09:12 PM | #5 | |
That chart will work on Sub C's and Lipo's. Some smaller cells,if you follow that chart,you'll bust the cells open,or stand a good chance of it. Getting your cells warm is a good thing.....cooking them is a bad thing. Last edited by Reflection; 08-19-2008 at 09:28 PM. | |
08-19-2008, 09:15 PM | #6 |
is that pack sub c cells? Sorry for the total noob Q's, trying to learn this stuff
08-19-2008, 09:23 PM | #7 |
08-20-2008, 06:14 AM | #8 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
Use 5-8 mv per cell for the wolfpack and the digital piranha.
08-20-2008, 08:13 PM | #9 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
I would never go past 5mv per cell. Generally 3mv or less is safe othewise you can kill packs.... I have alot of customers killing packs because they set it higher.
