08-21-2008, 10:30 AM | #1 |
Rock Crawler Join Date: Apr 2008 Location: SO CAL
| Lipo Taps question
Im looking to buy a lipo pack.....I have a common sense Ultra Balancer(ub-26) and was wondering what tap style I need to order to be compatibale with this balancer. Reading around and searching, I figured it might be a polyquest/hyperion, but just want to confirm before ordering my lipo pack. It has 2.5mm spacing on pin connection. I also have an adapter for it that makes the spacing much smaller but its at home and not sure on the spacing of that one. Im sure that is the adapter I have, and that one has 2mm spacing, on the website it said thunder power so, I think I found my answer Here is a picture of it, any help is greatly appreciated Last edited by nmanuel01; 08-21-2008 at 10:42 AM. |
08-22-2008, 12:05 AM | #2 |
Quarry Creeper Join Date: Dec 2006 Location: dot com
That looks kinda like my astroflight "blinky". Supposed to be sort of universal, but yeah I had to buy an adapter for T-Power. Is it marked on the board as to which way to plug it in? like with a +or -. I think mine says "black wire" on one end, as long as you get the orientation right it will balance as many cells as it has lights.
08-22-2008, 08:56 AM | #3 |
I ended up buying the tpower adapter and ordered my batt with t power taps, the guy at the hobby store said it looked a Hyperion plug would fit right in
08-22-2008, 08:59 AM | #4 |
Hyperion is 2.5mm spacing, so you would need that adapter bit in your second pic, but in reverse direction from female 2mm to male 2.5mm. Most packs are 2.5mm spacing. |
