08-22-2008, 07:31 PM | #1 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| Kind of confused - DX3R help.
Ok, I am loving the DX3R but the thing is weird. When I setup everything earlier today with Castle on the phone we got it all to work. Yes, I am new to this technology. I am used to 2 channel am from years ago. Anyway it worked great. I came back from work and turned it on and I have no throttle response at all. I searched and searched and have found issues galore but nothing works. I reset endpoints. I rebound. I re-calibrated the esc. I know I should read more, but I have read for hours today on these things. MM/BEC/7T/1500's/5955/225 THanks for the help. |
08-22-2008, 07:42 PM | #2 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
There have been a few models that would loose their bind. Mine has done it a couple times. You can sent it in and they will fix it, but they say once you re-bind a time or 2 you wont have the problem. Mine hasn't messed up on me in a long time and it only happened twice.
08-22-2008, 07:53 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
On the Castle there is a setting to change the start up time. It needs to be higher when using a spektrum to allow the receiver and DX3R connect.
08-22-2008, 09:39 PM | #4 |
Weird thing is now I turned it on and it worked? I have the rate on the DX3R set to 16.5 right now. Was that it? Chops - how would I know other than having the issue? Were there specific models? BT - I will check the castle software. |
08-22-2008, 10:16 PM | #5 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
| go to the spektrum website and they have the serial numbers that were affected by this problem
08-24-2008, 10:11 AM | #6 |
| I don't think the frame rate would affect the binding. I could be wrong though. I know some esc's wont work because of the delay when the tx and rx first "see" each other during start up. I guess if you can use the Castle software to allow it to work I would start there. My TX's serial # is included in the list on the Spektrum site but I have not sent mine in since it hasn't messed up since those first couple times.
