08-22-2008, 11:59 PM | #1 |
Quarry Creeper Join Date: Mar 2004
| 2 cell lipo vs 3 cell lipo.
Will I really notice the difference? I am trying to figure out what to run, and I can't figure it out. I am running 8 NI-mh cells on my stock axial ESC for a few months now. I did run 9 cells for a bit. If I run the 2 cell LIPO will I REALLY notice the big difference there? I know it is a 7.1volt VS 11.1volt. Thanks DIma |
08-23-2008, 12:04 AM | #2 |
um, YES! i run 3 cells and ill never go back. i used to run 8 cell NIMH, and thought it was awesome. when i first tried an 11.1v i thought "no way, too ****in fast!" but now i don't know what i would do without it. my berg 2.2 can do J-turns on smooth floors and pull wheelies on carpet with 45t lathe motors.
08-23-2008, 12:09 AM | #3 |
I wanna be Dave Join Date: May 2006 Location: akron
yeah I got to second that 3s is the way to go.. just gear down.
08-23-2008, 12:17 AM | #4 |
Thanks guys. I will be buying my 3 cell this week. Wish me luck with the RTR Axial ESC hahahahahaa DIma |
08-23-2008, 04:50 AM | #5 |
Rock Stacker Join Date: Jan 2005 Location: WEST BY GOD VIRGINIA
my turck also runs the 3 cell, the 11.1v...lipos are very light...make sure you have some sort of protection voltage cutoff when you use the lipos...you can pick up a novak safety device for like 20 bucks if you esc is not equipped!
08-23-2008, 10:07 AM | #6 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
flatty, 11.1v is the ONLY thing i will run in my rig. get yourself a sidewinder esc (or a mamba if you have extra cash to burn). i cant believe i ever wasted my time with nimh. |
08-23-2008, 12:49 PM | #7 |
Quarry Creeper Join Date: Jan 2008 Location: akrowdy
i run max amps 3c 11.1 lipos and love them great punch long lasting run times ... wit a sidewinder just set the cutoff and our good to go ...when u go lipo you will never go back ...
08-23-2008, 05:01 PM | #8 |
You guys keep takling about a cutoff.... is that the BEC? If so, why is one necessary? What does it prevent? Thanks Dima |
08-23-2008, 05:13 PM | #9 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
the cutoff is a voltage cut off , if a lipo drops past a certain level, it will not be able to be recharged, some esc's like the mamba max come with a lipo cutoff, novak also sells, a 2 and 3 cell cutoff that can be soldered to your current esc, i use mamba maxs and prefer 3 cell 11v lipos
08-23-2008, 05:34 PM | #10 |
by discharging your new lipo battery too much you'll destroy it. the cells will puff up and possible explode. you might as well light $50 on fire and stand back.
08-24-2008, 12:49 AM | #11 |
What would be the difference between these 2 batteries (as far as discharge goes) http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack (30~40C) http://www.unitedhobbies.com/UNITEDH...00mAh_3S1P_25C (25C constant 30C burst) Also can you tell me how much runtime the difference will be with these 2? Also, what kind of BEC would I need on these. Thanks Dima |
08-25-2008, 11:38 PM | #12 |
Rock Stacker Join Date: Apr 2008 Location: Greenville, SC
I checked these links and I wood go with the 2100, hands-down! The reviews for the 1000 are not good at all. Also just for information: BEC = "Battery Eliminator Circuit" U will need a 3-cell BEC, or one that can handle 11.1vdc. |
08-26-2008, 09:26 AM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Where do you guys mount the 3-cell Lipos? Got any pics?
08-26-2008, 09:36 AM | #14 | |
Run time?? the 1400mah will give you about a third more time than the 1000mah. The capacity (fuel level) of a battery is stated in amp-hrs (mah = milli amp hrs) So the 1000mah has 71% of the capacity of the 1400mah. It's like comparing gas tanks, in this case it's like a 20 gal to a 14gal tank, which do you think will give you a longer range with the same engine? | |
08-26-2008, 09:37 AM | #15 |
08-26-2008, 09:44 AM | #16 |
AreCee- What mah capacity 3S Lipo did you put there? (got a link to the vendor you used?) Some of them look kind of big. Also, what kind of runtimes do you get with it? |
08-26-2008, 10:39 AM | #17 | |
I get to do some practice, finish a comp and play afterwards on one charge. About an hour or so, I really don't know because I never ran them until the cutoff kicks in. Comps are five minutes per course! | |
08-27-2008, 08:49 AM | #18 |
Quarry Creeper Join Date: Aug 2008 Location: Yuma
I would like to see some pics also, I am very new the the crawler scene and need all the good info I can find
08-27-2008, 01:52 PM | #19 |
AreCee- is this the one you got? X-Caliber 25C 11.1v 1300mah lipo |
08-27-2008, 04:03 PM | #20 | |
I bought the one from Value Hobby, it's 3S, 11.1V, 67mm long, 1300mah, 20C and only $20.99 with $3.99 s&h. http://www.valuehobby.com/product_de...d=8&item_id=25 | |
