08-25-2008, 03:55 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
| E-Maxx EVX ESC good for dual motor crawling?
Anyone running this esc for a dual motor setup? I'd like to start a super comp crawler using RC4WD raptor axles. two battery inputs and two motor outputs |
08-25-2008, 08:12 PM | #2 |
Newbie Join Date: Mar 2006 Location: Denver
Ya, they work good but the EVX 2 is even better Waterproof and Better BEC: http://www3.towerhobbies.com/cgi-bin...&I=LXSLU9&P=ML |
08-26-2008, 12:00 PM | #3 |
Pebble Pounder Join Date: Jan 2006 Location: Canada
Just run a CC BEC with the EVX and it will work fine.
08-26-2008, 01:09 PM | #4 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Good idea I can't see why it wouldn't work. It would be even cooler to set a dig on it as well.
08-26-2008, 03:48 PM | #5 |
Well, I had an old E-Maxx that I parted out but kept the electronics. So I have the ESC. As for the dig....I have a good idea. Small servo hooked to an arm that turns a tiny switch on or off. That switch runs in line with one of the wires to the rear motor. Would that increase voltage to the front motor?
08-26-2008, 04:03 PM | #6 |
Quarry Creeper Join Date: Apr 2007 Location: Barrie, Ontario
It would be much easier to just use a Pico switch. Just put it on a 3rd channel and click
08-27-2008, 10:52 AM | #7 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I used to run an EVX in my Clod with an RX pack and the single pack mod... It worked extremely well with 27 and 35t motors... I was getting in excess of an hour run-time, as well... It's a good choice to start with... I also ran a DUD dig and that worked good as well, but I didn't do the lock the wheel mod with it... Maybe in my next DUD foray, I may make it a 3p... The DUD dig is a great and easy way to dig a Clod... But I don't remember if the front got more juice or not... I don't think it did... But with another ESC that's "single motor", it just might... |
08-27-2008, 11:28 AM | #8 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
They don't have a drag brake and the delay will bite you. It's not a bad setup, but there are some situations that the truck will roll back or forward and you can't stop it.
08-27-2008, 11:34 AM | #9 |
Pebble Pounder Join Date: Dec 2006 Location: nampa
10-29-2008, 01:33 PM | #10 |
Newbie Join Date: Oct 2008 Location: mredian
on my emaxx the evx is water proff shold use that in what works good. |
