08-26-2008, 04:15 PM | #1 |
Pebble Pounder Join Date: May 2008 Location: El Paso
| mamba max Problems!!!!!!
ok i have a mamba max and i am having a helluva time getting my transmitter to link up to the ESC! i have the latest version and my epa's for the throttle are set at 120% i don't know what to set my subtrim to and i have the dead band at the smallest setting aswell and i also reversed the throttle on it...........i am using a Futaba 3PJ super. i can't get it to link up!
08-26-2008, 05:13 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
Is that a Spectrum Radio? I had a buddy that always had trouble getting his Mamba to link with his Spectrum Radio. It was something about the Mamba having to set up, and the radio searching for a channel. Sorry Im no help, but it sounds like a similar problem.
08-26-2008, 05:17 PM | #3 |
Quarry Creeper Join Date: Oct 2006 Location: Japan
I had a similiar problem but with the Spektrum I believe it was due to the throttle EPA not set to 100%. Do a search as I think it someone had the same problem before ;)
08-26-2008, 05:37 PM | #4 |
Rock Crawler Join Date: Jun 2008 Location: dublin
Did You " Bind" The Radio And Reciever ???
08-27-2008, 09:41 AM | #5 |
Rock Stacker Join Date: Jun 2008 Location: On the rocks
| The receiver is bound. His issue is that the Mamba is not finding neutral. The Mamba blinks like it should at FT and FB than just blinks yellow. He is using a Futaba radio and not Spektrum. |
08-27-2008, 10:46 AM | #6 |
i will try setting the EPAs at 100% instead of 120%, maybe that will help. i did a search and had no luck, but then again i might be searching the wrong way, |
08-27-2008, 11:23 AM | #7 |
Newbie Join Date: Feb 2007 Location: Gainesville
If it isn't finding center then you need to increase the deadband via castle link.
08-27-2008, 01:19 PM | #8 |
I ended up having to reset the Transmitter and it linked up just fine, i'm an idiot! thanks for all the help guys!
08-27-2008, 01:28 PM | #9 |
Good to hear, now if you could only learn to drive it.......:-P
08-28-2008, 08:19 AM | #10 |
