08-27-2008, 02:45 PM | #1 |
Newbie Join Date: Aug 2008 Location: NY
| DX3R and four wheel stering
Some one can help me to setup a Axial rear stering with a DX3 spektrum radio? Can I use this radio and 4 W stering? Thanks for answer |
08-27-2008, 03:49 PM | #2 |
Newbie Join Date: Jun 2008 Location: In the Desert
The simplest way is to plug in your rear steer servo into the aux channel, and then in the menu go to system > switch select > and what I did was on the E switch go to Aux 3P. That will make your rear steer a 3 position. Hope this helps!
08-27-2008, 07:05 PM | #3 |
Thanks RacerTim...I still not with the DX3R, but...how the 3 possition will work in one switch?
08-27-2008, 08:36 PM | #4 |
on the grip of the DX3R there are two rocker switches -- 3 position -- and one button. The 3 position switch will make the rear steer move left, center, and right.
08-28-2008, 06:03 AM | #5 |
Newbie Join Date: Jul 2008 Location: Outside Champaign
| other option
I went with the rear servo in AUX (other option gets into "Y" or mixing cables). I then went in and used the Mixing function (aux follows steering) for mine in addition to the toggle setup (you can play with the percentage of rear to front). I had to use sub trim to get return to center to come back to straight ahead when using the toggle. That lets me use the toggle when in a tight spot, or for just getting around it does wonders for turning radius without having to think about flipping the toggle. |
