09-01-2008, 08:39 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
| major mamba max/motor glitching issues
I recently bought a used mamba max from the for sale section on the site to replace my rooster crawler for my upgrade to lipo. this is the problem, when I apply throttle, doesn't matter how much, lets say I apply 25% throttle, the car will go but after a random period of time it will glitch backwards at 25% throttle and if I increase the throttle, the intensity of the glitching seems to increase too. Also, when by servos were in a bind, the servos would glitch between trying to zero out and trying to push the wheels where they are supposed to be, this problem was solved when I installed a cc bec. the mamba max still glitches though and I have a comp on wednesday and I want to know if there is anything I can do to decrease the glitching
09-01-2008, 08:44 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
What TX/RX? Antenna wiring? Metal to metal contact within the chassis?
09-01-2008, 10:07 PM | #3 |
I am running a tq3 but the problem persists with a dx3 installed, I don't have any metal to metal on my chassis that I have noticed, here's a pic of my setup- |
09-01-2008, 10:18 PM | #4 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
How do you have the CC BEC installed as far as the wiring?
09-01-2008, 10:35 PM | #5 |
Pebble Pounder Join Date: May 2008 Location: Tyler, Texas
I have this same problem too to some extent, I programmed the start power to medium from high and set the dead band to average, and it eleminated some of the problem, I am running the delrin zero chassis so i'm not sure it's a motor noise problem... not trying to highjack, just combatting the same issue btw, my bec is wired directily to the esc deans, and i'm running a xr3i Last edited by mexiCAN; 09-01-2008 at 10:38 PM. |
09-01-2008, 11:43 PM | #6 |
Rock Stacker Join Date: Jul 2007 Location: Wollongong Australia
Have you removed the red wire from ESC going to the Reciever? If it is connected, then there will be major issues from what i understand. I cant see from that picture if you have it removed or not. Also, on the Castle Creations website, there is mention of glitching problems being caused by the orange wire on the CCbec. You might also want to remove the orange wire from the CCBEC plug just to make sure. Please make sure you insulate both wires when removed from plug as to avoid shorting out against any other wiring or terminals. Hope that helps Frank |
09-02-2008, 12:31 AM | #7 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
09-02-2008, 05:19 PM | #8 |
I have my bec plugged into the battery jack on the receiver and I have the esc power wire removed
09-02-2008, 08:42 PM | #9 | ||
RCC Addict Join Date: Nov 2007 Location: BV
How is the mamba programmed? Do you have caps on your motor? Try getting your receiver farther away from the motor and motor wires. Castle support is extremely good, while they might not get you taken care of in time for tomorrow's comp, they will straighten it out soon if you get in contact with them. | ||
09-02-2008, 08:47 PM | #10 |
Another thing just occurred to me. Try reversing and re-centering your throttle channel, and re-programming your ESC. It can't hurt to try.
09-02-2008, 08:50 PM | #11 |
my mm is programed with- forward/brake/reverse 100% brake 100%reverse punch control disabled 100% drag brake start power high 9v cutoff (I have checked to make sure this was right many times) normal motor timing brushed reversing motor type I do have caps on my motor but I think I may need my comm turned/new brushes, would that make a difference? I moved my antennae away from the motor/motorwires and it seemed to help a little, yet the problem is still evident even with a spectrum radio |
09-02-2008, 08:51 PM | #12 |
09-02-2008, 08:59 PM | #13 | |
09-02-2008, 10:36 PM | #14 |
RCC Addict Join Date: Mar 2008 Location: SSF
I haven't had this issue but I know others that have. They corrected it with the alt BEC wiring, only the servo will get BEC power, the Rx will get ESC metered power. I don't have the link handy, sorry. |
