09-05-2008, 06:37 AM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
| radio setup question
ok i just bought a dx3r, after binding it to my radio, no problem there. but after that the truck creeps forward on its own! what do i adjust to fix this! i used to have an m8 b4 with no problems
09-05-2008, 06:48 AM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
I can't remember what the default settings are right now since I don't have mine with me, but one of the buttons will be your throttle trim. You can go into the menu and go to Monitor and see how your trim is set, but as far as normal throttle and steering you should be able to see it from the main screen. If that doesn't work check to see what your Sub Trim is set at. I'll check back once I'm home tonight to see if you've got it fixed up, cause it'll be easier if I'm looking at mine. |
09-05-2008, 06:53 AM | #3 |
nevermind i got it figured out! had to reset my esc
