Thread: help with electronics!!!
Old 09-13-2008, 11:38 PM   #1
Default help with electronics!!!
ok guys i got my berg built as a roller. im trying to figure out the electronics part now. i have a cc bec, traxxas reciever, frt/rr dig switch, hitec steering servo, and a traxas evx2 esc. i have used to search button but came up a little shy. i need a diagram with the ccbec, dig switch, and an on &off switch all hooked up with my esc.
can some one help me please!!!
crawlercrazed is offline   Reply With Quote
Old 09-13-2008, 11:52 PM   #2
Rockcrawler's Avatar
dig setup and wiring?
There are a few threads about the Berg digs in this section.
Rockcrawler is offline   Reply With Quote
Old 09-14-2008, 12:38 PM   #3
Power of the Portals
Crawler, I have a drawn out diagram wired for the bec and on/off switch. Let me try and get drawn up on comp.
eric113 is online now   Reply With Quote
Old 09-14-2008, 08:46 PM   #4
This is a version I drew up while working on mine, it is taken from pup's diagram on here, it worked flawlessly:
Last edited by HomerJ; 09-14-2008 at 08:50 PM. Reason: Giving credit to the proper person..
HomerJ is offline   Reply With Quote
Old 09-14-2008, 11:19 PM   #5
Zero!
this is the one i would use like homers diagram , it disconnects the neutrals and no amps are going in untill the normally open (no) connection is clicked on dynamic brakes who would of thought they could use it in crawlers .... trains but a crawler
jombo is offline   Reply With Quote
Old 12-19-2008, 01:10 PM   #6
back to the top instead of starting a new thread.
EDIT: I have it all figured out :homer: Everything is working properly and I got to do some snow wheeling to break it in. Im stoked on how it crawls and the wheelspeed with the go button. Its sweet to have front digs with the back wheels locked
Thanks for the diagram
slicknic is offline   Reply With Quote
Old 12-19-2008, 03:43 PM   #7
Rev
Crawlerado
Rev's Avatar
Im wiring up my berg today and had a question inregards to the BEC. If I follow this diagram do the wires on the one end of the BEC not get used? Im using the castle one and it has a servo style plug on one end and the red black wires on the other.
Sorry for the lame question but im still learning
If you look in the Electronics section of this forum there are a ton threads that will show you exactly how to set it up. If you still have the packaging for the BEC it has a diagram on how to connect it.
Rev is offline   Reply With Quote
Old 12-19-2008, 03:56 PM   #8
hitman46mod's Avatar
I have a question what purpose does the red wire serve in the diagram? Does it short out the motor or does it equalize current the the circuit?
hitman46mod is offline   Reply With Quote
Old 12-19-2008, 04:17 PM   #9
Kamikaze's Avatar
It connets the + and - on the motor.
Kamikaze is offline   Reply With Quote
Old 12-19-2008, 05:41 PM   #10
Old 12-20-2008, 01:45 AM   #11
Linux Mint 10
JeepinDoug's Avatar
DPDsurf drew this one up really quick for me, simple.
JeepinDoug is offline   Reply With Quote
