Thread: More than 10K mah on a 3C?
Old 09-15-2008, 04:18 AM   #1
Location: ************************ Why crawl, when you can just jump up there?!
Default More than 10K mah on a 3C?
I was looking into MaxAmps 3C 10k mah lipo. Has anyone heard of a company that makes more than 10Kmah for a 3C? Thank You.
Heres the Lipo: http://www.maxamps.com/Lipo-10000-111-Pack.htm
Rocky
ADDICT is offline   Reply With Quote
Old 09-15-2008, 12:00 PM   #2
Frontside Jones!
Chris_The_Battery_Man's Avatar
Ive never heard of such a thing in a reasonable size. It's probably enormous....
Chris_The_Battery_Man is online now   Reply With Quote
Old 09-16-2008, 01:34 AM   #3
I guess it's good for those 8 hour R/c crawling expeditions
Jack Smash is offline   Reply With Quote
Old 09-16-2008, 11:34 AM   #4
Back in the WATER!
dpdsurf's Avatar
For that price you could get 4 or 5 Thunder Power 1320's which would give you 4 to 6 hours of crawling time. That thing is big (2.32"x6.22"x1.26") and heavy, not worth the performance sacrifice IMO. Also look into the Thunder Power 2000mah's, I get 2 hours out of those and they are a littel wider with the same length and height as the 1320.
dpdsurf is offline   Reply With Quote
Old 09-16-2008, 11:48 AM   #5
sloppy's Avatar
so you are assuming this is going in a crawler???
AKRCC you could always parallel 2 of those packs.. chris is right size is gonna be a issue if you want more MAH then that.. but since the application is unknown maybe you have room..
sloppy is offline   Reply With Quote
Old 09-16-2008, 11:50 AM   #6
Back in the WATER!
dpdsurf's Avatar
Silly me, I thought I was on rccrawler.com. :-P
Old 09-16-2008, 12:10 PM   #7
Frontside Jones!
It's a low C rated pack. The Elite 5300's are much bigger and a 30C pack. So for a 10,000mah pack to be truly 10,000mah, it would have to be twice the size or with these dimensions, 1/4 the C rating.... Probably would be a good pack for low amp draw situations to accomplish high runtimes. But even running it in a Brushless car you would only see 15-20 mins.... or 6 mins at the 100 amp constant they rate it at.
Old 09-16-2008, 12:22 PM   #8
sloppy's Avatar
Originally Posted by Chris_The_Battery_Man View Post
It's a low C rated pack. The Elite 5300's are much bigger and a 30C pack. So for a 10,000mah pack to be truly 10,000mah, it would have to be twice the size or with these dimensions, 1/4 the C rating.... Probably would be a good pack for low amp draw situations to accomplish high runtimes. But even running it in a Brushless car you would only see 15-20 mins.... or 10 mins at the 100 amp constant they rate it at.
that explains the low price.. he would be way further ahead getting 6 5300's and doing a 3s 2p setup more MAH higher c rating little more cost but it is a much better pack..
Old 09-18-2008, 01:51 AM   #9
So a 2P Elite 5300's is gonna be my best bet your saying.... hmm i better look into it a little more. Theres LOTS of room so I was just wanting 3C and a super high mah. Thx guys.
Rocky
AKRCC
Old 09-18-2008, 10:31 AM   #10
Frontside Jones!
Rocky
AKRCC
Yeah if you want a good stout pack that is True C and Mah rated... But as I tell my customers... 10 AH is like running 2 5 AH packs.... so just get 2. Or I can easily build it into a 2P pack. I am going to use a 2S2P of them in a sand rail setup. But they are HELLA long! PM me if you have questions.
