Thread: Choppy Dig servo, kinda..
Old 09-17-2008, 10:36 AM   #1
Default Choppy Dig servo, kinda..
Ok, here's the situation.. My dig servo (Hitec Mighty Mini) is set up as a 3 position switch to operate a electric dig for a berg and it activates one of two micro-switches. It goes from left, to center, to right. From center to left and back it works full speed like it's supposed to. But when I go from center to right, it acts like it's binding, it only moves about 1/4 to 1/8 speed and it's choppy. There is no pressure or resistance on it other than the micro-switches that it's hitting. Going from right, back to center is full speed. When I put my finger on the servo horn, it will not move at all, but it should be able to move the weight of my finger I would think. I'm not holding it, just resting my finger on top of it. When I hit the control to activate the servo it just shakes back and forth like it's confused lol. I've checked my framerate, it's at 11ms. It's on a freshly charged and balanced battery. Any ideas?
HomerJ is offline   Reply With Quote
Old 09-17-2008, 11:36 AM   #2
You could have some channel mixing weirdness going on but I would bet the servo is on its way out. You can try a different servo in the reciever port to see if it still does it to trouble shoot.
j33pownr is offline   Reply With Quote
Old 09-17-2008, 11:37 AM   #3
Mixing is inhibited... after talking to my lhs guy, we're both on the consensus that it's about to go poopie... Thanks for the input though!
Old 09-17-2008, 11:52 AM   #4
Ok, just plugged in my 645 for the heck of it... it does the same thing... Soo.. I decided to mess with my travel values for the servo. Raised both ends of it quite a bit. That got it working right again. Moved them back down to where they originally were at, and all is well.. Any idea what could have caused that??
Old 09-17-2008, 12:21 PM   #5
Bergs are worthless...just mail the POS to me and i'll dispose of it..
Insane
Rastus is offline   Reply With Quote
