Thread: sometimes loose power when crawlin up CC M Max
Old 09-17-2008, 06:21 PM   #1
toy4crawlin's Avatar
Default sometimes loose power when crawlin up CC M Max
Help please
Just got my new Super running about 7 LBS
most of the time I cannot crawl up slow, power cuts out
Mamba Max, not warm, makes squeak noise, crawler starts rolling back down
BM16 brushless
NEW 8 cell Sub C battery
axial tranny 81 spur 19pin also tried 87 / 23-way to high
1/8 scale ring/pinion 13/43 3.3:1
Do I change setting in ESC ? or is my gearing to high and what should it be?
finding gears to fit axial is not easy, need to find correct setting or right Spur to buy 2 Spurs that will provide good results
I cannot fit 81 spur 18 pin, maybe a 82 /18 or 83 18
thanks
toy4crawlin is offline   Reply With Quote
