09-21-2008, 10:54 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: bel air
| sidwinder questions
I am going to be getting the axial artr and i was thinking about getting the sidewinder esc and an integy 55t motor or the navak crawler brushed kit. With the sidewinder can the integy motor plug into it and how do I put tamiya style plugs on it?
09-21-2008, 11:37 AM | #2 |
The Sidewinder comes with 4mm bullet plugs...so you will need to solder leads to the motor with those size plugs. The power wires come open (no plug) so you can solder either a Tamiya or deans plug...whatever you choose. Here is a pic: If you are planning on getting this ESC, it would be a good idea to also pickup a Castle Link. It really helps with custom programming of the ESC. |
09-21-2008, 12:09 PM | #3 |
Pebble Pounder Join Date: Nov 2005 Location: Back in MICHIGAN
but honestly who has em in stock right now, i tried everywhere that i can think of and everyone is on back order.
09-21-2008, 08:17 PM | #4 | |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
And X2 on getting the Castle Link. You will have to change the motor setting from Brushless to Brushed for the Integy motor. I have 3 Sidewinders now and I love em. | |
09-22-2008, 05:54 AM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
I use these... http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTJ21 from motor, cut off the bullet connectors and soldier these... http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTJH8 These will plug right into the CC sidewinder. Also, as mentioned above, buy the castle link for programming. It's set to run brushless motors from the factory. Won't work with an integy. You must change it. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGVR8 for added security, buy the CC BEC. I didn't at first but needed to later on in the build. Castle Creations recommends using it in their sidewinder http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSWL3 here's a tamiya plug set... http://www3.towerhobbies.com/cgi-bin...&I=LXSGL0&P=ML good luck |
09-22-2008, 12:44 PM | #6 |
Quarry Creeper Join Date: Oct 2007 Location: Toronto, ON. Canada
please dont use tamiya plugs.... man up and do that extra 5 min. of soldering and get yourself some deans plugs |
