09-26-2008, 09:58 AM | #1 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Quick FXR Question
Are you guys running the FXR on 3s lipo? The manual says the FXR is rated for 2s and the FXR-Pro for 3s. I just assumed that the FXR could handle a 3s and 2 55t's?? Thanks |
09-26-2008, 10:23 AM | #2 | |
I wanna be Dave Join Date: Jun 2004 Location: Whales
Tekin has stated that they will honor the warranty should we use a 35 turn or higher (45, 55, etc....) using the 3C Lipo setup | |
09-26-2008, 10:23 AM | #3 |
Newbie Join Date: Aug 2008 Location: Lower Mainland, B.C.
The manual is wrong. You can use a 3s lipo as long as you are using a 35 or more turn motor. |
09-26-2008, 10:32 AM | #5 |
Thanks for the quick help This is why RCC kicks azz
09-26-2008, 10:35 AM | #6 |
Yes, 35 turns on a 3S is okay, but remember when you use two motors like on the Bergs and run them in parallel (like you should) you're cutting the number in half. Two 55 turn motors in parallel is about the same as a single 27 turn. So keep that in mind. I do know plenty of people are running even lower turn motors in their Bergs with a single ESC... personally I use a pair of 65 turns. I also recommend an external BEC if using a 3S lipo. |
09-26-2008, 10:54 AM | #7 |
Rock Stacker Join Date: May 2008 Location: united states
several people are using a single FXR w/3clipo and 35 turns on MOA's, I have seen others use Cobalt puller 7t's also with 3c's with no issues on the FXR. Using a external BEC is highly recommended when using 2 motors and 2 servos |
