10-10-2008, 04:27 PM | #1 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
| cc bec problems again
Ok just got a new DX6I and a JR 8711 and cc bec. Hooked up everything first without bec,worked great. hooked up bec just like all diagrams show. I unplugged red wire coming out off novak rooster crawler,hooked power up to leads coming from batt to esc. It would glitch if u applied throttle fast but not if you did it slow.After about ten minutes light went out on cc bec.Any reason why I cant just use the bec thats in the novak.
10-10-2008, 05:18 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: wahiawa
the rooster crawler esc has a built in bec in it...did you program the ecs correctly and how is the reciever?
10-10-2008, 05:32 PM | #3 |
| Right I unhooked red wire from esc ,Everything programmed correctly but after a few mins of running around trying to figure throttle glitch all reciever lights and bec light went off. Just hooked back up red wire on rooster and all runs great. I guess i am just not meant to run a cc bec.
