Thread: 2 different servos ok??
Old 01-06-2008, 11:10 PM   #1
Default 2 different servos ok??
i have 2 different servos. JR z900t and a JR ds8711. is there any reason why i cant use them both on the same truck?? both high torque digitals. front and rear steer clod.
U4EAH is offline   Reply With Quote
Old 01-06-2008, 11:22 PM   #2
If one is stronger than the other, the weaker one might break and leave you screwed.
2JSC is offline   Reply With Quote
Old 10-15-2008, 11:10 PM   #3
Also the stronger one might make the weaker one feel insecure and cause it to have poor performance issues.
Ripperfi is offline   Reply With Quote
Old 10-15-2008, 11:43 PM   #4
if you want to use 2 on one end, they have to be the same. Otherwise mix it up, it shouldn't hurt anything.
chrisjlittle is offline   Reply With Quote
Old 10-16-2008, 07:02 AM   #5
Big Mike's Avatar
lol - that was good!
Should'nt matter, I've done it myself. I put the stronger servo in the front, weaker in the back. Since the back only serves as a sort of emergency measure if I get stuck or need to find that little extra bit of traction. And for cutting tight turns, of course.
Big Mike is offline   Reply With Quote
Old 10-16-2008, 08:09 AM   #6
yes, put stronger up front, but you also want to think that the rear can pull you out of tough situations, so you don't want a really weak servo in rear (really not important, but good to consider)
and also i cant find the z900t on the jr website.........?
arow884 is offline   Reply With Quote
Old 10-16-2008, 09:01 AM   #7
PapaGriz Yo
Grizzly4x4's Avatar
I run a Hitec 5955TG in the front of my super and a Hitec MG945 in the rear.
The 945 is a bit too weak but there is no problem with mixing servos.
Grizzly4x4 is offline   Reply With Quote
