Thread: Tekin FX-R internal BEC ...
Old 11-02-2008, 05:18 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default Tekin FX-R internal BEC ...
Is it good enough to run an MRC or do I need a CC BEC as well?
I'm thinking I'd like to run this ESC with a hitec 255mg for the steering, so it would only be running a spektrum RX and a mini servo. That should be fine right?
Locked Up is offline   Reply With Quote
Old 11-02-2008, 05:21 PM   #2
MODERATOR™
EeePee's Avatar
Totally good enough.
EeePee is offline   Reply With Quote
Old 11-02-2008, 05:27 PM   #3
Locked Up's Avatar
Hell, what if I run my AX10 steering servo right off a CC BEC and let a little Tekin power my dig and a 225mg dig? So the steering would get a signal through the RX but it's power leads would go right to the BEC.
That means I could crank up the voltage to crazy high on the BEC
Old 11-02-2008, 09:11 PM   #4
yeah that would work as well!
bigflex is offline   Reply With Quote
Old 11-02-2008, 09:24 PM   #5
Locked Up's Avatar
Yep, that's what I just did and it's a lot cleaner now. I still need to get a mini deans for the servo/bec connection but I have a lot less wires and less crap in my RX now.
Sweet.
