11-04-2008, 03:47 AM | #1 |
Rock Stacker Join Date: Apr 2008 Location: Vienna
| question about connection esc - motor
hi I am not much of an electrician, and have the following question: does connecting the motor to the esc with such a device has any negativ impact (electronically)? device: sincerly |
11-04-2008, 05:40 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Just the current loss and resistance from the connector. Tamiya connectors have been known to melt, regularly. I don't know about the current load that that connector can handle but it is best just to direct solder the ESC and motor.
11-04-2008, 06:21 AM | #3 |
Pebble Pounder Join Date: Apr 2008 Location: Aurora
If you are looking to be able to disconnect your motor from your esc i would go with bullit connectors. Castle Creations make some nice ones also you can get them from eflite as well, any well stocked rc shop should have some to choose from. Just know what size wire you are using, they come in different sizes. |
11-04-2008, 06:33 AM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
11-04-2008, 07:36 AM | #5 |
Depending on the bus bar inside that connector, it may work pretty well actually. can you give any more details about it? Should be just fine. If it gets warm you should use something else however. |
11-04-2008, 08:41 AM | #6 |
RCC Addict Join Date: Jun 2008 Location: Fresno
2 words: deans connectors |
11-04-2008, 08:45 AM | #7 |
Even better, 4mm castle plugs. You can swap polarity easily this way.
11-05-2008, 12:07 AM | #8 |
hi i think it is brass inside sincerly |
11-05-2008, 05:55 AM | #9 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
11-05-2008, 10:28 PM | #10 |
hi the polarity-problem shure exists. |
