11-13-2008, 07:45 PM | #1 |
Newbie Join Date: Jun 2007 Location: port st. joe
| sidewinder esc
i was wanting to know what yall thought bout the sidewinder esc. is it a good one for crawling? i found one pretty cheap and wanted to know if it had good drag brake and all. i appreciate the help.
11-13-2008, 07:53 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
its a great esc for crawling, you can program it to how ever much drag brake and throttle you prefer.... make sure you get a castle link to do so though...
11-13-2008, 07:59 PM | #3 |
thanks man, i just bought it and already have the castle link. thanks so much man. later
11-14-2008, 11:25 AM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: Portsmouth UK
I have mine on 90% drag in one of my scalers and it runs downhill perfectly,with no throttle input. Love it! |
11-14-2008, 01:37 PM | #5 |
Rock Stacker Join Date: Aug 2008 Location: Canada eh
I've got one i tore out of my buggy to put into my truck and love it. but i'm far from an expert on things electrical. I'm using it with a integy brushed 55 turn motor. it seems to hold in hills pretty good I'm becoming a very big fan of castle products, have a mamba max in the mail for the buggy (or vice versa, we'll see) |
11-15-2008, 02:32 PM | #6 |
Quarry Creeper Join Date: Jun 2008 Location: Phoenix
I run a sidewinder on my Axial artr and it works great. the castle link is a must though. lets you change aything you want to also comes in handy when trying to program you castle bec
11-17-2008, 12:59 AM | #7 | |
Pebble Pounder Join Date: Dec 2007 Location: CA
so, I can use as a guide line. Thanks. | |
11-17-2008, 04:26 AM | #8 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
I have a Mamba max and a sidewinder there is one thing that i havent read on here yet, These esc have brakes forward and reverse. If your truck is rolling either direction on a hill and you want it to stop. Just barely move the trigger and It will lock it up. I run my drag brake at 100% Forward and reverse at 100% Lipo cut off at auto sensing so i can run a 2s or 3s All the other settings are at Default. Thats just my style and were i drive. |
11-17-2008, 05:18 AM | #9 |
Yep the sidewinder is perfect to run any 2.2 or Super rig (2 ESCs of course).
12-15-2008, 05:49 PM | #10 |
Newbie Join Date: Dec 2008 Location: cincinnati
Is everyone running the sidewinder 1/10 scale esc? Is this the one that is brushed and brushless ready? Is there anyway to program the esc other than using the castle link? I am trying to decide between the sidewinder or rooster crawler. Any thoughts?
12-15-2008, 06:47 PM | #11 |
Rock Crawler Join Date: Sep 2007 Location: University City
| yes its the sidewinder 1/10. You can "stick" program it, however the castle link is worth 10x its weight in gold. The ability to adjust the power/brake curves, as well as pretty much everything else is invaluable. No longer are you stuck with a couple of preprogrammed curves, you can now tune it to your particular driving style and location. but i dont have an opinion |
12-15-2008, 07:47 PM | #12 |
So what do you do with the 3rd motor lead if your using a brushed motor instead of brushless? Can the sidewinder be programmed for zero delay between forward and reverse?
12-15-2008, 07:51 PM | #13 | |
Quarry Creeper Join Date: Jul 2008 Location: Asheboro N.C
Yes it can be programmed with zero delay. | |
12-15-2008, 07:53 PM | #14 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
| You just leave the white wire loose or unhooked. I would also leave the bullet ends on the Mamba Max or Sidewinder, you may want to run brushless later and not have the bullet ends on there is a PITA! And yes you can have 0 delay if you want |
12-15-2008, 07:54 PM | #15 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
You just dont use the third wire ( white one ) , It has ZERO delay forward to reverse. I used to run a Rooster Crawler , I would never buy another one now , Castle Sidewinder for brushed motors , there is no other.
12-15-2008, 09:11 PM | #16 |
Rock Stacker Join Date: Nov 2008 Location: oakdale
how many lipo cells cannit handle?? going 11.1volt and need to replace the rooster.........
12-16-2008, 06:14 AM | #17 |
Pebble Pounder Join Date: Mar 2008 Location: Rock Springs
12-16-2008, 11:23 AM | #18 |
Newbie Join Date: Mar 2006 Location: Denver
I have ran mine on 4cell lipo with the red wire pulled out and a receiver pack.
