08-23-2005, 09:05 AM | #1 |
Newbie Join Date: Oct 2004 Location: YANKTON,SD
| wiring a lathe motor
I am new to this and just got my integy 55t lathe motor and noticed it has what appears to be 4 places for wire connections. What is the correct way to wire it? I am running an evx with one battery on a modded e-maxx. thanks |
08-23-2005, 10:01 AM | #2 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
1 lead to the + side and one to the - .... the top of the end bell right next to the bearing says what side is what there should be a little + sign for the positive side.
08-23-2005, 10:11 AM | #3 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| One side is positive, and the other is negative. Look for the (+) or (-) stamped on the endbell. |
08-23-2005, 10:45 AM | #4 |
Quarry Creeper Join Date: Aug 2005 Location: Redding, True Nor-Cal, look on a map
Remeber that if you are running a clod one of the motors will be wired with the positive off the speed controll to the negative on the motor. Otherwise you won't be going anywhere fast.
08-23-2005, 12:06 PM | #5 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
or you can wire it normal and reverse the end bell.
08-23-2005, 01:37 PM | #6 |
OK. I seen the positive symbol. The other 2 spades that have the screws thru them are of no concern then?
08-23-2005, 01:50 PM | #7 | |
08-23-2005, 05:29 PM | #8 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
Is there a need to run caps on the lathe motors or is interference not an issue?
08-23-2005, 06:51 PM | #9 |
umm i run them on my lather motor just because i had the soldering gun hot and the motor out... i would run them just because but it really depends on your electronics...
08-24-2005, 06:14 AM | #10 |
Does anyone have a pic of a lathe all wired up to make this super simple?
08-24-2005, 10:09 AM | #11 |
wow its just like n e other aftermarket motor u buy... ill try to get a pic later. Last edited by nd4spdbh; 08-24-2005 at 10:15 AM. |
08-25-2005, 12:06 AM | #12 |
Newbie Join Date: Jul 2005 Location: Columbia
Here you go. The blue wire is connected to the negative and the yellow to the positive. |
08-25-2005, 06:50 AM | #13 |
I know, I put more into it then it really is, but this is the first motor I've had with an endbell that looks like the pic you showed. Guess I don't want to fry anything. And thanks for the info and pics.
08-28-2005, 11:56 AM | #14 |
Pebble Pounder Join Date: Jul 2005 Location: vandenberg afb
| thanx
thanx every body i was up all last night iam still up from last night but i finaly got my rig put together i have had this thing for over 2 mo just getting piece by piece this is my first electric and my first custom job thanks again |
08-31-2005, 10:52 PM | #15 |
Newbie Join Date: Sep 2004 Location: San Diego area
To continue this in a little more detail...can I use the two smaller leftover terminals to solder the caps to...versus soldering them to the can itself?
09-08-2005, 07:39 AM | #16 | |
varcor.org Join Date: Aug 2005 Location: 757
09-08-2005, 01:05 PM | #17 |
you cant be serious.
09-08-2005, 02:50 PM | #18 | |
12-09-2005, 12:04 AM | #19 |
Pebble Pounder Join Date: Nov 2005 Location: Millmont
I have a question. I wired m lathes like the pics above shows, but my motors wouldn't work. The ESC would make a noise, got really really hot but nothing happened. Do I need to installed resistors capacitors on the lathe motors? If so, can someone please post a close up pic? This is my first electric R/C and I'm a little lost. I'm using to Integy lathes, a Rebel 2, and all this is in an NN chassis. Thanks |
12-09-2005, 07:48 AM | #20 |
sounds like you have shorted your esc. Make sure that you are wiring to the positive and negative sides of the motor and not just to one side. redbull- yes you can use the little tabs instead of soldering to the can Urbanace's pics are pretty up close and clean. |
