11-22-2008, 10:50 AM | #1 |
Newbie Join Date: Aug 2008 Location: san diego
| Balance Tap For Lights
DOES ANYONE KNOW IF YOU CAN USE THE BALANCE TAP ON A 2 CELL MAX AMPS LIPO TO PULL POWER TO RUN LIGHTS |
11-23-2008, 10:11 AM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
It will run the lights if they are 3-4 volt. It will also unbalance your batt pack. If you do this I would keep a very close check on the balance. Charge at a low rate and use balancer. Even if you use the 7.2 volt rate watch your cell voltage.
