11-26-2008, 11:06 PM | #1 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
| Dig servos
Anyone using the HS 85MG for a dig servo? Went to the hobby shop today and they didnt have the HS 81. |
11-27-2008, 06:21 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I don't see why it wouldn't work. There's no stress on them, and those things will handle the 1/18 scale buggies and trucks.
11-27-2008, 06:44 AM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
If I remember right, isn't the 85 a little stronger than the 81, but still the same size? I have a buddy that ran one on an R2D, with no problems, other than not enough power!
11-27-2008, 06:51 AM | #4 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
I only use a 55, So a 81 will work.
11-27-2008, 09:38 AM | #5 |
11-27-2008, 12:01 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
I have used one in the past, works fine just alittle big for the task.
11-27-2008, 12:03 PM | #7 |
Any micro server will be up for the task. I bought a pair of cheapo off eBay for like 10 bucks....no problems
11-27-2008, 12:19 PM | #8 |
Pebble Pounder Join Date: Mar 2008 Location: Rock Springs
I used the 55 in mine, had to go with a smaller servo due to my did is in a box, but so far no problems. thanks |
11-27-2008, 04:00 PM | #9 |
I actually had a spare Futaba 9650 sitting around. I still have one more and a slightly better quality JR servo still kicking around. These are servo's for 1/12 scale onroad cars. Way overkill. But for the purpose of clicking a micro switch, any thing will do.
11-27-2008, 08:51 PM | #10 |
Rock Stacker Join Date: May 2008 Location: united states
X2 on the HS-55, I have been using one for some time now with NO problems and @ 13.00 brand new @ my LHS you cant beat it |
11-27-2008, 08:58 PM | #11 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
Pretty much any servo will work. For me it is depends if it will fit on the chassis to get the best lowest CG as possible.
11-27-2008, 09:01 PM | #12 |
Yeah, I was really tired last night......I was actually meaning to ask who is using these in a Zero chassis with the dig plate. Mine should be here tomorrow or Monday so I guess I will find out then. |
11-27-2008, 09:22 PM | #13 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I use the cheapo dx-6 servos. Go to joey's, he will have some, if you can pry them away from his dungeon......
11-27-2008, 09:26 PM | #14 |
I will only use the Hitec 5595TGs for my dig. |
11-27-2008, 09:31 PM | #15 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
The cut out in the dig tray is .492x.958 I run a Hitec 65hb servo that measures .450x.940 and still have to clearance the round corners of the tray and the holes on the servo to bolt it in. so I would say the servos you listed are not going to be a drop in and go setup. Jeff designed the tray around the servos that come with the DX-6 radio which are pretty small. |
11-27-2008, 09:32 PM | #16 |
Yeah, they are a standard micro servo. Hey Joe, your caliper is off, they are .4953 x .9615........ |
11-27-2008, 09:37 PM | #17 |
There is no way they are that far off. |
11-27-2008, 10:16 PM | #18 |
