| | #1 |
| Devoted axle fan ![]() Join Date: Nov 2008 Location: Greece, sun, sea and rocks
| While I was messing with my rc stuff I noticed that the transmitter of my kyosho MFR uses a 3 position switch for reverse neutral and forward. Naturally I tried to use it in my ax 10 with an HR dig. It works quite well but there are drawbacks: A) This tx is budget stuff and has no EPA or DR to trim servo travel but I trimmed using appropriate holes in the servo horn. B) It is a simple 27mhz am tx which does not bother me since I usually hold it 2 feet away from the model (I am very short C) The rx is HUGE twice the size of a typical airtronics 3channel blue rx. Now for the pros: A) It is very light even with 8AAs installed B) Unbelievably reliable, I have happened to use a similar perfex tx with an rc boat for more than 6 years by the sea (salt!) on the beach and generally has never failed me, it is kyosho after all. C) It is cheap!!! I saw them go on ebay.co.uk for about 35 to 45 euros or around 50$. D) It is very ergonomical for my liking since the 3 position switch is easily usable with the throttle thumb. E) Since it is not computerized, a set of dry cells lasts for bloody ages!!!! F) it is compatible with other brand 27 am rx, I tried with a Futaba rx and worked great. The exact model is Perfex KT-10. I do not know if this is of any help to anyone but sure helped me avoid tinkering with other txs I have since here in Greece rc stuff is still quite expensive. Thank you for reading!!! |
| Sponsored Links | |
| Thread Tools | |
| Display Modes | |
