Thread: 1/4 scale servo hook up questions
Old 08-20-2004, 02:25 PM   #1
MWRCA'er
Mnster's Avatar
Default 1/4 scale servo hook up questions
Right now I have two standard servos with 111oz of torque.
From what I have read in the previous posts 1/4 scale servos require a receiver pack because of the high drain. I'm going to get the cs 80's so those come with a Y-harness. Would the servos be fine running on 7.2 volts in series? Because series would divide the voltage between the two servos right? I know to low right. Or maybe I could wire a cooling fan system to take some of 7.2 voltage away. What voltage would I need to power two servo.
I can get 7.2 lithium Ion packs for cheap.
http://www.allelectronics.com/cgi-bi...35&type=store#
Or should I just make a few packs of nimh
http://www.allelectronics.com/cgi-bi...100&type=store
http://www.allelectronics.com/cgi-bi...10T&type=store
Mnster is offline   Reply With Quote
Old 08-20-2004, 03:21 PM   #2
Default Re: 1/4 scale servo hook up questions
I think you mean parallel? They'd only be getting 3.6 each though then, although I bet those on 3.6V would still tear the sh!t outta anything that got in their way!! I might do that, cause I'm afraid the CS80 is too much for my knuckles.
SR5Dave is offline   Reply With Quote
Old 11-21-2004, 04:24 PM   #3
any updates on this setup?
i just ordered two of these servos for my crawler and was thinking of doing the same, splitting a 7.2 batt between the two servos.
Lunatic is offline   Reply With Quote
Old 11-21-2004, 05:59 PM   #4
don't forget that with series the easiest one will get most of the power.which usually is the rear,the one that don't need it as much
SPEED_RACER is offline   Reply With Quote
