| | #1 |
| Newbie Join Date: Aug 2008 Location: Cape Coral
| Please Help I just got a Novak 55T brushed crawler motor and I heard of some people breaking them in is that true??? It has a little clicking in reverse.... Runs fine but what should i do??? break in????? PLEASE HELP...... |
| Sponsored Links | |
| | #2 |
| Team meeting! ![]() Join Date: May 2008 Location: Two Harbors, MN
| IMO I dont think motor break in is needed for a crawler. All your doing on break in is seating the brushes with the com so you have top performance your first run. As far as the clicking sound im not sure but when I ran brushed motors in my AX-10 I heard a clicking in reverse with Integys 55t and 75t. I wouldnt worry about it. |
| | #3 |
| Newbie Join Date: Oct 2008 Location: in a box
| There is a short break in period on some motors so the brush's come in full contact with the commutator. as to your clicking check and see if the set screw is close to the spur the motor has a little bit of play and when you reverse rotation the shaft may move slightly and the set screw hits the teeth of the spur. |
| | #4 |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| Some people break them in. I broke mine in crawling around on some rocks. Some folks even put them in a glass of water while they break them in to let the brush shavings float to the top! Saw a picture of on here but cant find it now. |
| | #5 |
| Pebble Pounder Join Date: Mar 2006 Location: TAOS NM
| Mine hade a clicking noise like the first 3 packs it will go away. As for brake in i dident brake mine in i just went out and drove it like its going to be run for the rest of its life!! Its a great system i was conserned about the clicking also at first. |
| | #6 |
| Thanks much.... The clicking is with and without any spur gear on it its in the motor..... I just hope it goes away..... |
| Thread Tools | |
| Display Modes | |
