08-27-2005, 12:37 AM | #1 |
Newbie Join Date: Oct 2004 Location: Folsom, CA (NOR*CAL)
| ESC questions
i have an e-maxx with all aluminum a-arms, spools f/r, gd-600, 55t lathe motor and stock receiver. i have a super rooster esc and when i drive about 10 or so feet away from me it starts glitching like crazy, i was wondering if anyone knows why it might do this??? also i was trying out that trick were u short out one side of the stock EVX ESC. if i plug only the battery in and not the connector that shorts it only the front steering works, then when i plug the connector that shorts it, it does nothing??? if anyone could help me with either of my questions that would b awsome!!!! westsidecrawler |
08-27-2005, 06:56 AM | #2 | |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
as for the glitch,that can be a # of things that cause this.first i'll ask-did your truck ever run with out the glitch with this trx & rx in it?keep your rx and it's ant away from any thing metal-alum-cf,and away from any wiring.make sure it's as high as posible.you don't want it below any of the above i mentioned.have new or fully charged battery's in the trx.make sure the rx ant is the orig length.is the motor new?if so,was it broken in?motor also needs 3 caps for each motor(if running 2)some people don't but they are not having a problem,you are so you may need to try them. | |
08-27-2005, 09:30 AM | #3 | |
Quarry Creeper Join Date: Aug 2005 Location: Redding, True Nor-Cal, look on a map
This write up is easy to follow and it works great. I use an evx in my clod and have no issues at all. | |
08-27-2005, 09:50 AM | #4 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
westsidcrawler02, there's no need to ask the same question in 2 different forums. http://www.rccrawler.com/forum/showthread.php?t=14780 |
08-27-2005, 10:35 AM | #5 | |
08-27-2005, 10:51 AM | #6 |
sorry for postin it twice, i was just tryin to get as much help as possible. and ive read the evx write up like 4 times and i thought i did it right but i guess i didnt. |
08-27-2005, 10:59 AM | #7 |
It's pretty simple, plug the battery in, on light come on (correct location for battery cross the other two) if the light doesn't come on, try the other connection.
08-27-2005, 11:08 AM | #8 |
what do u mean by cross the wires?? like solder them together
08-27-2005, 11:23 AM | #9 |
Newbie Join Date: Aug 2005 Location: Mountain Home AFB
| Another question
I read the write up about the EVX controller but what it did not mention is abou tthe stock TXT-1 motors. The write-up mentions removing one motor because of the 14-v requirement but the stock TXT uses 2 motors and one pack. Do I still have to remove one motor? Can I use the EVX with the mod done? Any help is greatly appreciated. Thanks. John |
08-27-2005, 12:36 PM | #10 | |
08-27-2005, 12:44 PM | #11 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
OK well for the glitching ishue its ur motor... it need capacitators on it...
08-27-2005, 12:47 PM | #12 | |
08-27-2005, 01:13 PM | #13 |
what capasitors, can i get them at my lhs, how much $$$ r they?
08-27-2005, 02:15 PM | #14 | |
Here's a link to installing caps Dumb Lathe Motor Wiring Question... | |
08-27-2005, 02:18 PM | #15 |
im not sure if like a lhs like hobbie people sells them but if they did they would probably charge you like 5 bucks for three... but u could go to radio shack and grab some of these http://www.radioshack.com/product.as...5Fid=272%2D109 ORRR if you have like an old radioshack rc car or just an rc car motor with caps on them you could rob it off of them... |
