![]() | #1 |
RCC Addict Join Date: Jun 2008 Location: Mudville
ok got a goat system (esc and 18.5 motor). i have developed a sensor wire issue on the motor. ? is can i install a NON sensored motor on the GOAT ESC. if i can, anything i need to do to make it work correctly? 2ndly, visa-versa, can i run the Novak 18.5 with say a MambaMax. what about the sensore wires? i pulled the goat until i hear from Novak on what to do to get the Goat System working proplery again. i installed my MM/5700 with 14t pinion. HOLY SHIT Batman, WHEEL SPEED is INSAIN, and i thought it was NUTZ with the Goat. any help you folks can offer would be appreciated. |
![]() | #2 |
Rock Stacker Join Date: Aug 2008 Location: BC Canada
I'd like to know the same sort of thing. I've got a max and a novak sensored motor (undisclosed :-P) for just a bit of wheel speed but nice low end. It cogs a bit but otherwise works great. I'm going to gear down a bit more and adjust my throttle curves on the max to dial out some of the start up cogging. Overall though it has been a great transition and worked well so far (crossing fingers). I don't know what the long term on this will be but so far so good. Need to find a way to deal with the sensor wiring though. Looks messy. any thoughts from the pros would be appreciated Last edited by DMC; 12-08-2008 at 04:11 PM. |
![]() | #3 |
You can run a sensored motor with a non-sensor ESC like DMC, but not vice-versa. The lack of sensor input causes the ESC to go into fail-safe mode or whatever and won't supply power to the motor. At least that's what happens on my Novak Super Sport brushless system. It just blinks at you indicating that the sensor wire is unplugged. This has got the wheels turning in my head. I may have to try my 17.5T Novak motor with my MM in my scaler just for yucks. Any bets on how long it takes for the magic smoke to come out? ![]() |
![]() | #4 | |
| ![]() Quote:
![]() | #5 |
for confirmation, then No, i can not run a non sensored mortor with my Goat ESC? is that correct?
![]() | #6 |
Correcto-mundo! The ESC needs sensor input to know where the rotor is (part of the locked rotor detection programming I imagine) and without it, it doesn't know what the hell to do with the motor...
![]() | #7 |
RCC Addict ![]() Join Date: Feb 2008 Location: Tekin, ID
Running a sensored motor on a sensorless ESC won't fry it, but you will see very poor performance I would imagine. Sensorless ESCs like the MM, our R1 and others have trouble starting the high-wind motors, ie. 17.5, 21.5. For crawling, sensorless is not the way to go, sensored or brushed and even I prefer brushed over sensored for motor control.
![]() | #8 | |
Newbie Join Date: Jan 2008 Location: BAMA
| ![]() Quote:
I used Tekin products like chargers and brushed ESC in the past and I remember them being first class. | |
