12-14-2008, 10:00 AM | #1 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| OK, what is frameworks.NET 1.1...........
when i went to install the castle link software it installed frameworks, what is it and do i need it to run my CC link program....also what's this microsoft logo varifcation that wasn't varified yet, i clicked don't install CC software but it installed it anyway....i saved my set up for my ESC then went to open it from my CPU it said if i opened it that it may harm my CPU....i just did a reformat of my hard drive to clean up some junk i had in it....now i'm running across this junk with the CC software, do i uninstall the frameworks or do i need it to run the link software...........bob .... |
12-14-2008, 11:59 AM | #2 |
ok 29 views and no body knows????????....thx ..............bob .... |
12-14-2008, 12:02 PM | #3 |
12-14-2008, 12:07 PM | #4 | |
RCC Addict Join Date: Jun 2008 Location: Wasilla
- tre | |
12-14-2008, 12:10 PM | #5 |
12-14-2008, 12:38 PM | #6 | |
| Quote: .... | |
12-14-2008, 12:56 PM | #7 | |
its made by MS kinda like a language, Coders use it as a base for makeing parts of some software..... and i beleive that CC link does use it. (someone else can explaine it better then that im sure but you get the idea.) dont worry about it. like i said. - tre | |
12-14-2008, 02:34 PM | #8 |
one other thing i noticed was when i saved my sidewinder settings to my CPU....then tried to open it to see what was saved and got a warning that if i open this file it could damage my CPU....so i just deleted the saved file, what's going on with trying to save settings and getting that message....or should i just use the print screen button.............bob .... |
12-14-2008, 02:43 PM | #9 | |
- tre | |
12-14-2008, 02:47 PM | #10 |
i'll get a print screen of the message after i get my sidewinder hooked back up in a feww mins...........bob .... |
12-14-2008, 03:05 PM | #11 |
here is how it saved it to my CPU.... here's the message i get trying to open it to look at it.... hope this helps what i'm asking.............bob .... |
12-14-2008, 03:12 PM | #12 |
okay. so thats the problem. with castle link you dont save the settings to a file as far as i know(and i have/use it all the time). the settings are saved on the ESC/BEC its self to check if your settings were saved run the castle link program again with the ESC/BEC plugged in and it will read settings from the ESC. maybe im confused here why were you trying to open a .dat file? like the error says .DAT files are system files. |
12-14-2008, 03:16 PM | #13 |
The .dat files are saved settings. I have about 10 of them, and you have to open them through the CC program. Open CC link program, file, open. .dat file for a stampede .dat file for a brushed crawler .dat file for a cobalt puller .dat file for brushess & lipo scaler etc. |
12-14-2008, 03:17 PM | #14 |
in the CC link program i clicked on file then download settings, a window came up to where i wanted it saved....i saved it....when i went to open it to see if it saved my settings as i set them i got that warning....all i did now was a print screen to save what i set the ESC at....i wasn't trying to save or open a DAT file just what i programed my sidewinder so i had a record of it for any changes later down the road...........bob .... |
12-14-2008, 03:19 PM | #15 | |
bob, you dont have to save it to see the settings just plug it in and the CCLINK will read ure ESC. ;D | |
12-14-2008, 04:08 PM | #16 |
RCC Addict Join Date: Jun 2008 Location: Mudville
framework.net is a network/computer path routing device/software most newer computers already have updated. just go to www.microsoft.com and search netframework. i think 2.2 is what i have on mine, but there may be a newer version by now. |
