12-18-2008, 07:38 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: HAY CAPITOL OF THE WORLD!!!!! weeeeeeeeee
| need your help with glitching. video included
guys i had a horrible glitch that i had narrowed down to the receiver i thought, well i changed radios and receivers and now it is almost gone but still happens under full throttle it has a cut out. i have a video here if someone could look at it and tell me what they think. http://www.youtube.com/watch?v=vXDhM...e=channel_page |
12-18-2008, 07:39 PM | #2 |
Does it happen outside of the house also? And give us some details of what's on the truck. |
12-18-2008, 08:23 PM | #3 |
havent had it outside since i put in the new receiver. it was horrible with the old futabo, it has an xl-5 a 35t warrior and a tq3 radio and receiver.
12-18-2008, 09:42 PM | #4 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
If you grab the wire that goes from the reciever to the Esc, does the glitching stop?
12-19-2008, 06:50 AM | #5 |
grab it where at the plug? or just in some random spot. I'll try it when I get home.
12-19-2008, 07:43 AM | #6 |
Quarry Creeper Join Date: Aug 2008 Location: in the basement cussing my broke ass rig
If you can afford it, I would suggest going to a Spread Spectrum radio system. I used to have several various glitching issues, but since I switched over to a SS radio, I have not had many issues with glitching. Also, watch how you route your wiring, when you cross power over or near signal, you can sometimes cause interference issues. People are probably sick of reading this, but a ferrite choke can usually end the EMF interference. I know this because it worked on several occasions for myself. Also check the motor caps, maybe there is a failing solder joint or something like that. |
12-19-2008, 10:12 AM | #7 |
i have a 35t warrior but I dont see any caps. Where are they supposed to be located at on these motors? also what is a ferrite choke?
12-19-2008, 10:15 AM | #8 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
thats your problem! if you are not using 2.4 gig transmitter and receiver - you MUST have caps! you need 3 of em.. one going from one motor lead to the other and one on each motor lead going to the motors can. fixed.
12-19-2008, 10:16 AM | #9 |
12-19-2008, 10:17 AM | #10 |
| http://www.radioshack.com/product/in...ductId=2103222 looks to be something to help stop interfierance.. im guessing it is not working. |
12-19-2008, 01:29 PM | #11 |
12-19-2008, 01:32 PM | #12 |
12-20-2008, 11:13 AM | #13 |
i soldered some on to the screw that you have to losen to get the can off. will this work as a ground or do i just need to do it to the can, because it has not stopped glitching yet, nest i will try and find a ferrite choke i guess.
12-20-2008, 04:14 PM | #14 |
If the screw you speak of is coming in contact w/the can, that would be fine. If not, stick 'em to the can.
12-20-2008, 09:00 PM | #15 |
well i have to admit the ferrite choke worked better than anything alse i have tried he wasn't BS'ing guys,
12-21-2008, 11:10 AM | #16 |
That's my job. That's what i do 5 days a week, 8 hours per day. Been doing it the past 8 years. So, every now and then i am on point... |
12-21-2008, 11:12 AM | #17 |
12-21-2008, 12:00 PM | #18 |
Pebble Pounder Join Date: Jul 2008 Location: Trumbull, CT
the other thing to get is a bec, sometimes the servo will take all the power for that second and stall the motor. once i went with a bec powering the steering servo i never had a problem again
12-21-2008, 01:34 PM | #19 |
Jombo brought up a VERY good point w/the BEC to keep servos from robbing power. Props J. |
