12-18-2008, 10:01 PM | #1 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
| Hyperion EOS0606iAD??
I just bought a new hyperion charger since I have some lipo batteries on order too. For now I am just gonna be charging my Nimh packs on it. I noticed that is will discharge them as well. Is it good to do that every once in a while to completly drain them or should just recharge them?
12-18-2008, 11:14 PM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
NIMH are not affected by memory. They don't really notice if you discharge them or not before charging. I sometimes set my 0606 to cycle mode that is full charge then discharge then recharge. I've noticed a little better performance out of my cells as it wakes them up a bit. This is only when I have time other wise I just charge.
12-20-2008, 02:13 AM | #3 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
I use my nimh packs only for racing which is only twice a month so I usually cycle them discharge to charge the night before and then just charge them as needed on raceday. On off weeks I will do the same discharge to charge cycle once. |
12-20-2008, 02:01 PM | #4 |
Quarry Creeper Join Date: Jun 2005 Location: in the middle of the pacific ocean
If you got the time and capability to cycle them, it really shouldn't hurt any thing to do it. Also like said above, it should wake the cells up some for that little extra punch.
12-20-2008, 03:01 PM | #5 |
They are 9.6V 8 cell packs what is a good discharge to put them at?
12-20-2008, 10:32 PM | #6 |
This chargers max discharge rate is 1.0 amps so that is the max it will discharge the pack at.
