12-26-2008, 10:20 AM | #1 |
| Help with mamba 25 and 454's
I haven't used this rig (DTX C.C.)that much because of the startup problems, any ideas might be helpful, remember i am running a mamba 25 with 2 454 motors, if you look at the video the start up is all jittery and as more power is applied it becomes somewhat stable, i also have a 995 tg servo and i am running a 40mhz 4ch radio, i have tried a spektrum radio in it and same deal, so we can rule radio glitching out. Video is being uploaded right now Last edited by cartronicshn; 12-26-2008 at 10:30 AM. Reason: Uploaded video |
12-26-2008, 10:34 AM | #2 |
What happens if you run just one motor?
12-26-2008, 10:40 AM | #3 |
Haven't tried that yet EP, i went with JRH recomendations on motor and esc since i got the from him, never evne crossed my mind the esc could be overamped with these motors, let me try, i'll report back |
12-26-2008, 10:47 AM | #4 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
You need a bigger speed control for 2 454's.
12-26-2008, 11:11 AM | #5 |
12-26-2008, 03:12 PM | #6 |
Did you reprogram your throttle points on the ESC?
12-26-2008, 03:26 PM | #7 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Maybe a silly question...but are you in brushed mode ?
12-26-2008, 03:55 PM | #8 |
| Just did that How silly do you think i am?, guess what, that was my problem all along, so i guess it doesn't matter how long you have been in the hobby, or how well you know your systems you can always make the simplest of mistakes and overlook it, but thanks to the forum and you guys i again a happy camper |
12-26-2008, 07:34 PM | #9 |
Glad it helped I felt stupid asking you that since I know you have been around the block,but as you said...sometimes the simplest things are overlooked the easiest By the way...been there done that |
12-26-2008, 10:31 PM | #10 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
How did you wire it up to the single motor? Also what settings did you use in the Castle Link?
12-27-2008, 09:17 AM | #11 | |
Their wired parallel, and i just disconnected one power cable to one of the motors, and i have medium start up power(still palying with it) until i can get the smoothest start up possible, right now it's a little jumpy, i have been playing around with the power curve also, i have 30% drag brake(personal preference), i have 50% brake, hope that helps | |
12-27-2008, 09:48 AM | #12 |
I dont see how the m25's are going to stay alive with 454's.
12-27-2008, 09:50 AM | #13 |
I had no problems with mine, but I did run it with 2/3a cells and not lipo. I heard one guy blew up a sidewinder with two 454s recently.
12-27-2008, 10:34 AM | #14 |
I am running 8 cell 2/3 nimh, i hope it survives, so far so good |
