Thread: Drag Brake with cc Sidewinder
Old 12-31-2008, 07:18 PM   #1
Default Drag Brake with cc Sidewinder
I put Sidewinder + 35T ( Sinner motor from R2J ) in my AX-10. I set the drag brake to 100%
but it can't hold my rig either on vertical climb or downhill ? Is it normal or something wrong ? please help. Thanks.
flybird is offline   Reply With Quote
Old 12-31-2008, 07:52 PM   #2
with brushed motors the brakes will be weak. especially if you're running a regular lathe motor. try some stronger springs
emaxxjeremy is offline   Reply With Quote
Old 12-31-2008, 07:59 PM   #3
TEAM MODERATOR
Reflection's Avatar
Or better yet,put a Cobalt puller in there. Standard mag motors all have a fair drag brake at best. A motor with cobalt magnets will have a stronger magnetic field from the stronger magnets,therefore a stronger drag brake.
Reflection is online now   Reply With Quote
Old 12-31-2008, 08:09 PM   #4
I've noticed this as well with my Sidewinder/JPC 45t.My buddy has a Rooster Crawler/55t combo & it holds great:-(
fordmike65 is offline   Reply With Quote
Old 12-31-2008, 08:14 PM   #5
TEAM MODERATOR
Reflection's Avatar
The magnetic field between those 2 motors should be dang near identical. Lower gearing can make a rig "seem like" it's got more drag brake. Tighter gear mesh can as well,but temps will go up. Different springs......
Old 12-31-2008, 08:22 PM   #6
Guess I can try stiffer springs 'till I get the moolah for a more powerful motor,but his rig is a bone stock ARTR,stock gearing.I swear if he's at full speed & lets off the throttle his damn tires skid to a stop
Old 12-31-2008, 08:28 PM   #7
TEAM MODERATOR
Reflection's Avatar
Well in my Axial with TALLER gears,10t puller and a Mamba Max with 100% drag brake.....at times it has flipped itself over coming to a stop.
Play around with your throttle and reverse curves also,that can help some.
Old 12-31-2008, 08:34 PM   #8
Rooster is a HOLD brake.... Mamba's are a drag brake. I thought the same thing with mine. The motor has nothing to do with the hold brake on the Rooster.... it's just a feature of the ESC. IMO it's too much hold..... makes it hard to descend a steep grade without flipping forwards. When I get my rig back together im going to try the mamba and see how I like it. It is nice to just be able to STOP on a steep incline and regroup.
Gst95dsm is offline   Reply With Quote
Old 12-31-2008, 08:39 PM   #9
When I find my CC cable I'll try that.I see how too much brake can be a problem too,but it would be nice to have a bit more braking than I do so that I have the option 2 rethink my lines for a second.
Old 01-02-2009, 08:48 PM   #10
Thank you for everyone input.
