09-02-2005, 11:29 PM | #1 |
Newbie Join Date: Aug 2005 Location: Plains
| First Project and steering trouble
I just finished my first build (TLT) and it was going good untill I started doing all of the wire work.I have a 55t lathe motor, Novak XRS sport reversible and a hitec 645mg servo (no 4ws). I have it all hooked up and the motor works fine but the servo will not do anything. I did accidently plug the esc into the batt. plug on the reciever but I realized my mistake and put it on the throttle channel. So now I turn it on and everything works but the servo any help would be appreciated. Thanks in advance.
09-03-2005, 05:45 AM | #2 |
Pebble Pounder Join Date: Apr 2005 Location: England
u prob hav but check all the wiring etc and plug is the right way around although if you hav a reciever battery i would unplug the esc, plug that in and check if the steering works then - as it could be that the ESC is not givving out any juice Although you may have done something to the ESC plug when you put it in the battery slot :? as on mine they are slightly different.. just a thought |
09-03-2005, 06:38 PM | #3 |
Thanks for the help, it turns out it was turned the wrong way.
09-03-2005, 06:56 PM | #4 |
Although swicthing your wires may fix your troubles. Something to keep in mind. I don't know if you have a rec. battery,do you? I've ran the XRS before in our Twin crawlers. The XRS doesn't have a BEC rating worth spitting on and can and probly will cause glitching and such without the rec. battery. Just thought I'd post up and give you a heads up if you didn't know already. |
