01-07-2009, 03:41 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Colorado Springs
| Determining needed power supply amps/wattage
I'm considering purchasing an EOS0610i DUO II charger and I'm trying to determine how big of a power supply I need. The most load I intend to put on the charger is 2 2s 8000mah LiPos. Does charging 2 packs at 8 amps each (at the same time) mean that I need a power supply of that provided at least 16 amps? Or do I really need to look at wattage instead? If wattage was the important factor, I'd be looking at 118.4 watts (if a 7.4V pack is charged at 7.4V, that would be a combined (2 packs at 8 amps each) wattage of 118.4 watts). In this case, do I not care about the output amperage (as long as the output volts x output amps > 118.4)? Thanks! Disclaimers: 1. Yes, I searched before posting. 2.. I don't know the true charging voltage. I guessed the 7.4. Feel free to say what the true (max) charging voltage is. 3. I know to include some headroom. I'm just trying to learn the basic math. 4. I'm not interested in using PC power supply. 5. No, I'm not planning on putting 2 2s LiPos in a crawler. |
01-07-2009, 03:48 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Contact Maxamps.com or CheaperBatteryPacks.com - either will have great advise! Or HolmesHobbies.com - Great advise as well. |
01-08-2009, 07:00 AM | #3 | |
Quarry Creeper Join Date: Aug 2008 Location: in the basement cussing my broke ass rig
01-08-2009, 08:57 AM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
Your assumption is correct. Bassically the 16amps, but the charger will also consume ~1 amp while charging as well. I would shoot for a 20-25A power supply. The closer you push a power supply to it's rating, the more punishment you're giving it. A little head room is a good thing, as the charger may surge a little when starting a charge cycle. Cheers, Rob |
