01-11-2009, 10:21 PM | #1 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| What is the BEST micro servo electro dig???
I have had it with burning up micro servo's. Yes I know how to set my EPA's. Ive been through 3 Hitec HS-55's and 1 Tower Pro blue case micro servo in 3-4 months. They dont last... Im just about to go 2 FXR's and a twin stick and be done with it... I am runnin my dig servo's off the ESC's internal BEC hoping they would last longer. Any idea what is the best micro? Ill spend the $$ Thanks |
01-11-2009, 10:37 PM | #2 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
Not the one your running. Pony up the $ and get a $25 dollar servo, OR GO TWINSTICK.
01-11-2009, 10:41 PM | #3 |
Let me guess which one you think I should do One more chance with the servo's then ill be two thumbin it....
01-11-2009, 10:44 PM | #4 |
Here is what Kamikaze says on a different tread. Running 2 esc's is more wiring, more hassle, more to think about when you are running. I run the switches, its faster and easier to control. Honestly when you don't have rear steer the 2 esc's looses alot of its ability. __________________ TCSCrawlers.com Kamikazekustoms.com Holmeshobbies.com Pantherteam.com Mayhem Eng.com Team Trinity.com Liposonline.com I agree, try another micro switch. DO WORK DRIVER |
01-11-2009, 10:49 PM | #5 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I've been running the cheapy spectrum servos that come with the dx-6. You shouldn't be burning them up, after all they throw around a 3-d foamy like its nothing.
01-11-2009, 11:08 PM | #6 |
| I know.... I have a theory.. Maybe since the dig servo's throw is so short that the motor's comm is getting dead spots at the servo's end points causing it to hesitate. When they start hesitating I trash em.. Damn brand new TP servo costed me a gate and a podium finish Sat..
01-11-2009, 11:58 PM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
question. What radio and steering servo are you running?
01-12-2009, 12:03 AM | #8 |
DX3R, JR DS-8711 for steering.. Steering servo is powered off of the external Castle BEC at 6v and the dig servo off of the FXR's internal BEC
01-12-2009, 12:06 AM | #9 |
If your running a DX3R and you have a digital servo for your steering(as I am sure you do) The analog servo's you are running are having premature failure do to the frame rate settings on the radio. I would go with a digital mini servo like a HiTec HS-5245 mighty mini. Its digital, the same size as a 225 and less than $50 with an aluminum horn. |
01-12-2009, 12:14 AM | #10 | |
01-12-2009, 12:17 AM | #11 |
| Yes the frame rate is adjustable. The only bad thing is it is across the board not independent.:-( So basiclly the best cure for your problem is to get a digital mini servo. |
01-12-2009, 12:30 AM | #12 |
| Is there a mico digital servo? The 5245 you mentioned is quite large and weighs 1.12 oz (im anal:-() The other one I was considering isnt digital, the Hitec 65-HB and weighs .38 oz. If I adjusted the frame rate to make life easier on the analog micro servo would my digital DS-8711 suffer?
01-12-2009, 12:42 AM | #13 | |
01-12-2009, 12:53 AM | #14 |
I think Ill try the hitec 5065mg. It looks nice and should solve my problems, we shall see Thanks bigflex |
01-12-2009, 12:55 AM | #15 |
