01-16-2009, 11:28 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: Willamette Valley
| Mamba max just flashes!?
I followed the programming instructions. I emailed Castle. They have a 24-36 hour delay on emails... I checked the programming with the castle link and updated the firmware and I clicked the update button. I am using a TQ2 radio. I've programmed my sidewinder a few times and had zero problems. I am running a brushless motor and the programming is set on brushless. Any help would be appreciated. |
01-17-2009, 10:46 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Have you tried to recalibrate the radio to the ESC? What color is it flashing? Does it try to arm at all, like give the first beep sequence but not the second? If it does try to arm then move your throttle trim and see if it finishes the arming sequence. Do you have the throttle setup for 70/30 or 50/50? Should be 50/50, you can use 70/30 but your neutral trim will be be out. |
01-17-2009, 02:54 PM | #3 |
It was 50 50. I switched the radio to my futaba and works fine now.
