01-24-2009, 09:56 PM | #1 |
Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
| need a servo horn that holds up
im tired of bending servo horns. both bending towards the servo and twisting sideways. i've been through 3 JRs and 2 from CKRC. so what are you guys using that holds up? since you are gonna ask its a JR 8711, bending horns on axial and berg axles yes i did search, went through a couple hundred posts and all i found was the robotronics that only looks beefier where the rod end bolts in and about the same in the arm |
01-24-2009, 10:01 PM | #2 |
01-24-2009, 10:05 PM | #3 |
how thick are they and what are they made of?
01-24-2009, 10:06 PM | #4 |
Thick enough, 6061 aluminum. You will never have an issue. I have been running these hard on a HEAVY super for many years without failure.
01-24-2009, 10:07 PM | #5 |
Rock Stacker Join Date: Jul 2008 Location: Tallahassee
01-24-2009, 10:09 PM | #6 | |
| Quote: | |
01-24-2009, 10:09 PM | #7 |
yah, thats the one i mentioned earlier. they dont look any stronger where im bending/twisting
01-24-2009, 10:11 PM | #8 |
One day I'll learn to read the entire post, sorry.
01-24-2009, 10:12 PM | #9 |
dont worry about it, im not here to bash you, lookin for advice like most of the others on here
01-24-2009, 10:14 PM | #10 |
I measured, 3.2 mm, trust me these are the beef, I guarantee it. You will rip your servo off or strip gears before you faze these.
01-24-2009, 10:18 PM | #11 |
over 3mm huh, thats the SWB one? might have to give them a try
01-24-2009, 10:59 PM | #12 |
Quarry Creeper Join Date: Aug 2008 Location: Yuma
| If you bend the Robotronic servo horn your doing something wrong. They are very strong. I ordered mine from ebay and they were a little cheaper. I think I got 3 for less than $20.
01-25-2009, 08:56 AM | #13 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
could it be the way your linkage is set up,or epas not adjusted properly?
01-25-2009, 02:42 PM | #14 |
its bending back from hitting stuff. twisting when its bound up
01-31-2009, 11:27 AM | #15 |
alright, i got the robotronics horn and it doesnt fit. JR 8711 servo and robotronics #23 JR horn. took the screws all the way out and tried prying the clamp apart... no luck. WTF
01-31-2009, 12:14 PM | #16 |
Are they the correct spline count? The Robotronics are pure beef: |
01-31-2009, 01:00 PM | #17 |
| http://rcpcrawlers.com/product.php?p...&cat=12&page=1 thats the one i got, says it for JR, hard to count the splines when some are cutout for the clamp |
01-31-2009, 01:36 PM | #18 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
| I thought the same thing when i got mine. They are just very tight... I had to use a little KY jelly and push like crazy, but it WILL fit. |
01-31-2009, 02:32 PM | #19 | |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
Good thing you had that tube handy then Edit: Sigged Last edited by Karadjas; 01-31-2009 at 11:09 PM. | |
01-31-2009, 03:30 PM | #20 | |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
here's a link http://www.horizonhobby.com/Articles...ArticleID=1455 Last edited by Cave Dave; 01-31-2009 at 03:32 PM. | |
