02-02-2009, 05:45 AM | #1 |
Newbie Join Date: Feb 2009 Location: Ontario,Canada
| Soldiering Brake line?
Is it possible to soldier brakeline or maybe even mig weld it (like tack welding)? I never tried it before just wondering as i want to make a tuber chassis.
Last edited by dootch; 02-02-2009 at 05:48 AM. Reason: Sorry i posted in the wrong section can you please move it. |
02-02-2009, 07:20 AM | #2 |
I believe brake line is galvanized....your best bet is to braze brake line.
02-02-2009, 11:40 AM | #3 |
Newbie Join Date: Jul 2005 Location: Albuquerque
| Brake line build info
Yes, you can solder brakeline. You need to use silver solder with the correct silver solder flux. Use a MAP gas torch. There is a good article here on rccrawler in the tech area on this. http://www.rccrawler.com/tuber.htm You can MIG or TIG weld brake line, but you need to sand off the galvanizing first. CAUTION: Welding anything that has been galvanized without removing the gavanized coating first will give off Cyanide gas - very toxic! Follow the directions in the tech article, and have fun! |
