02-04-2009, 01:21 AM | #1 |
Quarry Creeper Join Date: May 2008 Location: So-Cal
| Just got an FXR do I need a BEC?
When should I be using a BEC? Thanks in advance for the info guys.
02-04-2009, 01:38 AM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
It depends on you servos. I run nothing but hi torque servos so I run a BEC on mine. You will know if it starts glitching. |
02-04-2009, 05:38 AM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
Yea...its just a good investment...get a good one like CC and you'll never have to upgrade
02-04-2009, 05:54 AM | #4 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
I would recomend running a BEC on just about every crawler esc out there. I have 4 Tekin FXR's and run CC bec's with all of them....couldn't be happier |
02-04-2009, 05:58 AM | #5 |
Pebble Pounder Join Date: Nov 2008 Location: CO Springs
I'm running a fxr with out a bec 1 steering servo rated for around 200 oz It works fine Holmes told me if i run a larger servo or a 2nd one ( like for dig ) i would need one, so I did last week when i ordered my dig. |
02-04-2009, 07:28 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Voltage also matters. Mine ran great with a 8711 and no BEC on a 2S lipo. I moved to 3S lipo and things went bad! When you increase the input voltage, you decrease the amperage on output for an internal BEC like the FXr. Also if you run a dig, you might also have issues. For the $20 buy a BEC. |
02-04-2009, 09:26 AM | #7 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
yes i recommend the BEC for the $22 it costs
02-04-2009, 10:19 AM | #8 |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
What exactly is a bec and what does it do? JEFF |
02-04-2009, 11:08 AM | #9 |
Pebble Pounder Join Date: Jan 2009 Location: Vermont
Regulates a constant flow to the reciever.
02-04-2009, 01:59 PM | #10 | |
02-04-2009, 07:05 PM | #11 |
Newbie Join Date: Aug 2008 Location: Roseville
Is there a recommended brand, model ,o rating that folks are using? After reading this I think I may need a BEC. I'm in process of building my first crawler and did not plan on adding a BEC but I think I will need to use one. Any recommendatins? Willy
02-04-2009, 08:34 PM | #12 |
| Well kind of... but I use my CC BEC to power my steering servo directly....doesn't even go through the reciever (only the servo's signal wire goes to the reciever) Imo, a BEC works much better and is much more trouble-free if you use it to directly power servos (sending the power around the reciever) |
02-04-2009, 08:42 PM | #13 | |
http://holmeshobbies.com/product.php...&cat=13&page=1 | |
02-04-2009, 10:03 PM | #14 |
Pebble Pounder Join Date: Feb 2008 Location: USA
BEC stands for 'battery elimination circuit'. This is left over from the days when all rc cars had a receiver battery and when they were first put into the speedos. On 2s a speedo BEC is pretty decent, but can still be amped out with heavy servos or jammed steering. On 3s a seperate BEC is pretty much required with all 1/10 scale speedos. The new breed of 1/8 BL speedos have switching BEC circuits instead of linear regulators and can be used with up to 6S. We could add a switching BEC to the FXR, but it would more than double the size. Since the BEC is perhaps a more common failure point than the speedo it just makes more sense to have them seperate. They are cheap and easy to replace in a hurry or have a spare. Tekin Prez Last edited by Tekin Prez; 02-04-2009 at 10:38 PM. |
02-04-2009, 10:47 PM | #15 | |
02-05-2009, 09:11 PM | #16 | |
