02-05-2009, 04:44 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: UK
| yet another cc bec question
Here's my set up sidewinder esc hitec 7995 tg servo mini hitec servo for dig 55t novak tcs 7.2v saddle packs 1500mah cc bec question...what voltage should i set the bec to. 6V? could i also up the battery voltage to say 8.4v by fitting another cell to one of the packs? |
02-05-2009, 05:37 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
Set the cc bec to 6 volts...and the cc sidewinder will handle up to 11.1 volts so ans 8.4 will work fine. hope this helps... |
02-05-2009, 09:08 PM | #3 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
That HiTec servo will handle more than 6 volts but the benefits aren't worth the risk in my book, stick with 6 volts |
02-06-2009, 01:02 AM | #4 |
thanks guys
02-10-2009, 09:46 AM | #5 |
If the sidewinder will handle 11.1V it's ok to up the voltage to 9.6 then, obviously. But what difference will this make? more torque? Last edited by jordi555; 02-10-2009 at 02:30 PM. |
02-10-2009, 03:32 PM | #6 |
Newbie Join Date: Jan 2009 Location: Marysville
More voltage will give you higher motor RPMs and torque. I went to an 8 cell 1500 MaH pack and geared down a little bit.
