02-10-2009, 05:17 PM | #1 |
Rock Stacker Join Date: Nov 2007 Location: KamLOOPs, B.C., Canada
| Mini Servos: HS-5245MG vs. HS-225MG for Dig
Well, I got a decent deal on a Hitec HS-5245MG for my DNA dig, but came across something saying that digital is LESS forgiving in a bind situation therefor causing it to burn out? Should I return it and order the HS-225MG instead? Why would the digital servo be less forgiving? |
02-10-2009, 06:02 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
As long as you can set your endpoints then a digital servo will be fine. But if not - the digital will probably end up frying.
02-11-2009, 07:56 AM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
x2 set up the epa...and if you hear your dig not engaging correctly, just switch it back so you don't over stress the servo and kill it.
03-24-2009, 12:49 PM | #4 | |
Newbie Join Date: Mar 2009 Location: Humboldt County
I am considering buying either the 5245MG or the 225MG for my Losi MRC, I like the torque numbers for the 5245MG. I'm unfamiliar with digital servos, what do you mean by setting the endpoints and how would one do that? | |
03-24-2009, 01:04 PM | #5 |
You will be fine using those digital servos for steering and not messing with the end points (the points at which the gears inside the servo come to a stop). These settings are much more important when these servos are used for a dig (three different settings and the points are held for lengthy periods of time).
03-24-2009, 02:34 PM | #6 |
Thanks for the information
