02-19-2009, 10:34 AM | #1 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
| DX3R Aux channel/dig switch set-up?? Last edited by 53 willys; 02-19-2009 at 10:37 AM. |
02-19-2009, 11:28 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Make a switch on you controller 3 position by looking at the manual. Connect the servo to a power source without the servo horn, set your end points very low. With the servo on put the servo horn on so it doesnt touch either micro switches. Gradually work your end points out untill it will compress the micro switch enough to cut power then go slightly more to be shure it engages all the time. This should work, this is similar on how i did my shafty, its the same principle. |
02-19-2009, 11:39 AM | #3 |
crap I got it figured out...dang that was pretty easy once I got it... |
03-08-2009, 01:16 PM | #4 | |
Quarry Creeper Join Date: Dec 2008 Location: Route One
| Quote: I have the switches set @ A - thr B - str C - Inhibit D - Aux 2p E - Aux 3p F - Aux 2p what am I doing wrong? thanks | |
03-08-2009, 01:28 PM | #5 | |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
03-08-2009, 01:41 PM | #6 |
ahhh! off to rebind my RX. thank you sir |
03-08-2009, 01:43 PM | #7 |
03-08-2009, 01:46 PM | #8 |
didnt work..... went thruogh the bind process, steering works, but no dig servo movement |
03-08-2009, 01:52 PM | #9 |
Hmmm... Worked for me. Some of the smarter guys on this will pass through here and can help you further.
03-08-2009, 01:56 PM | #10 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
try turning up the epa up a bit, maybe it is set too low??? keep the horn off till you get it ...
03-08-2009, 01:58 PM | #11 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
Whats your servos?......ALso try putting you steering servo in the aux slot and see if the servo moves.
03-08-2009, 02:03 PM | #12 |
no worries, thanx for the help.... I will be doing inventory to see what good stuff I can part with in order to finance the two ESC method of dig.....the big cost is the new radio...too bad I just got this one. If the DX3R can run 2 esc's in the berg, the dig servo and switches are gonzo. Gotta look into that later today.....Guiness time right now, always helps me not break someone or my own stuff |
03-08-2009, 02:21 PM | #13 |
Rock Stacker Join Date: Jun 2008 Location: akron ohio
i dont know if this will help but make the c switch a trim adjustment for you aux channel. i know that is how mine is set up even though i never mess with c for my dig trim. also just try making one switch contol your aux channel and inhibit the other.
03-08-2009, 02:22 PM | #14 |
Quarry Creeper Join Date: Mar 2007 Location: Kerman, Ca
If your steering servo is of the digital type and your dig servo is not, you have to turn down your frame rate to get the dig servo to work. Hope that helps |
03-08-2009, 02:36 PM | #15 | ||||
I think I'm confused now but....I think I was confused before too I am running up and down the stairs between the basement and my den to use the PC.....I think the guiness is making me levitate...is that possible? | ||||
03-08-2009, 02:56 PM | #16 |
Thats your problem, you have your frame rate set at 5.5ms, which is for digital servos. Your Hs-65 is not digital. Change it to 11ms, if that doesn't work use 16.5ms. You want to fastest setting that will work with your servos. The 5.5 definitly won't work though. Hope this helps |
03-08-2009, 03:08 PM | #17 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
03-08-2009, 04:07 PM | #18 | ||
I guess I need a new servo anyway, I thought it was digital. bummer | ||
03-08-2009, 04:29 PM | #19 |
this is when I say okay, okay. time to go take the Gixxer out for a good ole git the anger out ass kicking! |
03-08-2009, 05:26 PM | #20 |
quick and dangerous.... too much sand on the road, got my fix though back to getting this thing straight! |
