02-19-2009, 04:23 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| Will my servo work at it's full strength at 5 volts?
My steering servo is rated for 425 oz. @ 6 volts, if my CC BEC is running at it's default 5 volts, is my servo still putting out all the power it's capable of? Or do I need to program the BEC to 6 volts? Also, is it safe to run those 6 volts through my reciever? Or would I need to run the BEC straight to the steering servo? Thanks. |
02-19-2009, 04:27 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Clermont
Not an expert, but would think you most definately want to get the full voltage to it, or you're really just robbing yourself. I have a TQ3 receiver, and a BEC programmed to 6.2v, and have no issue running it through there. |
02-19-2009, 04:39 PM | #3 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
The rec. should have no problems with 6 volts. I run 6.8 volts through mine. What radio gear? | |
02-19-2009, 04:41 PM | #4 |
I'll be running it with my DX3R and the rx it came with. 3100 I think is the model of the rx.
02-19-2009, 04:45 PM | #5 | |
I think sometimes the rec. would shut down under load or something. | |
02-19-2009, 09:24 PM | #6 |
Thanks for the help guys. I'll do some searches about voltage drop with spektrum stuff, but if anyone knows more about it, feel free to chime in. |
02-19-2009, 11:10 PM | #7 |
Pebble Pounder Join Date: Dec 2008 Location: California
i have a rooster 12t in my rally car and its built-in bec is rated to put out 6 v to the receiver, and i haven't had any problems with my spektrum receiver. btw, what is this monster servo you have that's rated to 425 oz-in at 6 volts?! |
02-20-2009, 06:32 AM | #8 | |
Your car is lightweight and you're not using a big servo so it's not the same. And it's not always about the voltage but the amperage that the servo draws. | |
02-20-2009, 06:52 AM | #9 |
02-20-2009, 06:53 AM | #10 |
Quarry Creeper Join Date: Dec 2008 Location: fairfield
the spektrum rx will handle 6v no problem, you should turn your cc bec to output 6v. as with my setup i got my bec only powering my steering servo. the thing i did notice with my bec is now im getting shorter run times. i believe its cause my servo is getting a constant 6v now as from before, when power would drop from the esc to the rx. i used to get about 30-40 mins of run time now i get about 25 mins of run time
02-20-2009, 10:37 PM | #11 |
| yeah, those are good points. i think it's only 1.5 amps so we're not really moving too many electrons. my li'l rally car's hardly lightweight though, those tb01's are pigs! i was thinking about finally making the switch to lipo and will get a bec anyway, but i'm really going to miss my power switch.
