02-20-2009, 10:08 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
| venom fireball 55t smoking
was driving and noticed it smelled hot next day saw smoke coming from it, disconnected the battery straight away. It's about a month old. I didn't have it bound up and the gear mesh was fine. been the same settings for about a month, I did just ad the CC bec a couple days ago, but that should put less strain on the motor right? anyone else have trouble with the new fireballs? Last edited by username; 02-20-2009 at 11:49 AM. |
02-21-2009, 08:27 AM | #2 |
Pebble Pounder Join Date: Mar 2007 Location: kalispell
| I had 2 of the Venom 50t go up in smoke in less than 5mins each on 7.4 2s lipos, call venom and they might send you a free replacement like they did to me... |
02-21-2009, 08:46 AM | #3 |
Rock Crawler Join Date: Apr 2008 Location: Wrightsville, PA
My Venom motor burned up the first time I ran it. Lasted about 20 minutes.
02-21-2009, 05:25 PM | #4 |
yeah, I am lucky to live about 15minutes from venom's office, so they gave me a 50t in place. if this one smokes, ill let them replace it one more time, and i will switch. i have an integy 65t in my other rig, its just much slower for my tastes, once i get used to the wheel speed! the 50t seems like enough torque for everything so far.
02-22-2009, 12:07 AM | #5 |
Looks like you had soemthing in it? I've been running 6 different Venom motors all on 3 cell lipos... No problems at all. And I'm far from easy on them.
02-22-2009, 12:35 AM | #6 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I'm no motor expert, but that big black line does not look normal. |
02-22-2009, 12:48 PM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
From the groove I can see the arm, it looks like a washer or rock or something similar got into the motor can. It wedged itself between the arm and the magnet, and dug down creating the groove (probably a mark in the magnets too). This led to MASSIVE amp draw, which in turn overloaded the windings until you smoked and threw a wind. You probably will need a whole new motor if the magnets got damaged in any way. One they get any damage, they become very brittle, so a bad fall can cause a chip to come loose and you will probably smoke another arm. Later EddieO |
02-22-2009, 02:53 PM | #8 |
Newbie Join Date: Jan 2009 Location: Buckhannon
I had a 60T that only had 2 or 3 packs through it when it smoked.
02-22-2009, 03:02 PM | #9 | |
02-22-2009, 03:52 PM | #10 |
unfortunately, the teardowns venom uses are some of the cheapest in the biz. They are made with very cheap magnets and they use a VERY crappy glue to hold them in.....so what more than likely happened, yer motor got warm from just running it, which softened the glue......which made the magnet spacer come loose as a magnet shifted. The cheap motors are cheap for a reason......hence why I suggest always getting a well made motor based of a good teardown. Venom is a good company, so you should not have any issues with getting a replacement from them. Later EddieO |
