02-23-2009, 05:55 AM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: GUAM
| dx3r steering set up help
trying to set up my dx3r with my servo but i think my servo has a brain of its own lol! well anyways the servo is acting weird when i turn left or right it just stays there it wont go back to neutral position!! can anybody help me out here????cry: |
02-23-2009, 06:04 AM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Pretty sure that's got nothing to do with your 3R, and everything to do with a bad servo. Hi Tec, JR, Tower? Digital or analog? Whatever it is, try it with another Tx if you can. If it still won't center I'd suggest sending the servo in for repair or warrenty. The only other thing it may be is if you're running REAL heavy front rims, the servo may not have the ability to center itself. I wouldn't put money on that since it's turning them in the first place, but you never know. Also try holding your crawler in your hand so there's no load on the wheels and tires, and see if anything improves. |
02-23-2009, 06:17 AM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Check the frame rate too.
02-23-2009, 07:06 AM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
yeah check your frame rate to make sure you have it set at 11....i had to do that myself with the 3R.............bob .... |
02-23-2009, 02:00 PM | #5 |
| dx3r servo setup
i tried messin around with the frame rate still the same and my servo is brand new and also when im trying to setup my esc with my radio its also acting weired when i pull the trigger set up light will flash on my esc but when i push the trigger to the brake position it wont register with my esc im gonna keep messin with this thing until i get it.
02-23-2009, 02:07 PM | #6 |
What servo? What ESC? What Rx?
02-23-2009, 03:08 PM | #7 |
| servo,esc,reciver |
02-23-2009, 03:17 PM | #8 |
Is the servo digital or analog? Are you using a brushed or brushless motor? Have you tried rebinding the Rx? Have you tried recalibrating the ESC?
02-23-2009, 03:26 PM | #9 |
| tried almost everything
I'm pretty sure its digi.and I'm using a brushless motor and I tried rebinding so many times and also tried recal.the esc the esc would read the transmitter on full throttle but when I try to cali. With full brakes it won't read it. |
02-23-2009, 03:29 PM | #10 |
| reciver
Could it possibly that its doing this cause I placed the reciver on top of the servo?
02-23-2009, 05:26 PM | #11 |
02-24-2009, 03:50 AM | #12 |
| thank you
thanks guys for the help got it figured out!! |
02-24-2009, 04:03 AM | #13 |
02-24-2009, 04:06 AM | #14 |
| settings
well i just had to set parameter(monitor set up screen) |
02-24-2009, 06:37 AM | #15 |
Glad you got it figured out. Sometimes all of those options with a Tx can be a bad thing...
