03-03-2009, 06:26 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Fraggle Rock
| DX3R Exponential ?
What does the exponential do for the throttle? Could you give me an example of a couple settings and how they would affect the throttle? I think I know what it does. But an example would help. What I want is a little more low speed control. And I think this is what I need to adjust.
03-03-2009, 07:01 PM | #2 |
Pebble Pounder Join Date: Nov 2008 Location: Hamburg, MI
It gives you a delay when you pull the trigger, turn it all the way up an play with it then turn it down a see the diff of what happens along with try it in the middle
03-03-2009, 07:06 PM | #3 | |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
03-03-2009, 11:04 PM | #4 |
Like a boss... Join Date: Feb 2008 Location: NorCal
With no expo. your throttle is a linear line. As you squeeze the trigger it correlates to a linear amount of throttle As you add expo...It puts your throttle on a "curve" that curve can either bow up or bow down depending on whether you add positive or negative exponential. How this affects the radio use and "feel" is it makes either the trigger less or more responsive at different points in its range of motion. Positive expo would make your trigger less senstive at the beginning and end of the trigger range and more sensitive in the middle. Negative expo would do the opposite. It's a very useful feature if your someone who wants to soften their trigger finger. If your "hammer down" kind of guy who can't seem to find the middle ground of throttle...expo can help with that. It allows you to over-react to your control movements and not have the control be as sensitive. You have to be careful though, you never loose full range of the so if the throttle curve is very sharp it (lots of expo) it will catch up quickly in the trigger and could make things worse for you. As 3speed mentions...I would try a little and see if it's something you can notice and like. Last edited by mann0mann; 03-03-2009 at 11:18 PM. |
03-03-2009, 11:11 PM | #5 |
I'm running a Holmes 25T in my Axial, and I dialed in about 50% negative expo on my DX3R to smooth out the low speed control |
03-04-2009, 12:52 AM | #6 |
Thanks everyone! You have been a great help.
03-04-2009, 08:32 PM | #7 |
