03-13-2009, 02:57 PM | #21 |
Waht version is the new one? have a link?
03-13-2009, 03:26 PM | #22 |
03-13-2009, 05:16 PM | #23 |
My problem is with vista on my vaio, it used to run before, but know it gives me an error message, software in esc is newer than the one i am running or not a valid c.c. esc?? , i have unistalled it twice and reinstalled as castle indicates, i even downloaded a net frame upgrade and no go, i can open the program no problem try to download the updates and it tells me there are no new updates, as soon as i plug either the castle link or the usb for my mamba max it gives me the error message, help please, i am at a loss here, it worked before:-(
03-14-2009, 06:40 PM | #24 |
anyone?:-(
03-14-2009, 06:50 PM | #25 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| yup
CC will not run on 64bit but it will run on 32bits (which version of vista do you have)
03-15-2009, 08:33 AM | #26 |
32 bit, and it ran before:?
03-15-2009, 09:21 AM | #27 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
03-15-2009, 03:49 PM | #28 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
03-15-2009, 07:04 PM | #29 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I installed the update today and I like it. For some reason in my Super, that annoying beep would cause my Hitec servos to glitch. This fixed that problem and I like the update for my 2.2 as well. This is just another reason why Castle Creation is the best in the business.
03-21-2009, 08:17 PM | #30 |
Rock Stacker Join Date: Mar 2009 Location: cali
there should be memory so you can listen to some slayer while youre gettin extreme on the rocks!!!
06-29-2009, 10:14 AM | #31 |
New 3.13 version is out, it has some new cool features, check it out. http://www.castlecreations.com/downloads.html |
06-29-2009, 12:01 PM | #32 | |
06-29-2009, 01:45 PM | #33 |
Carlos!
08-05-2009, 11:16 AM | #34 |
Hey guys, I plugged up today and there is a new firmware version for the sidewinder. It is 1.22(beta). The menu options have changed a bit. You can now change the direction of your motor without switching around your motor wires, and you can choose to turn the power-up beep on or off. pretty neato.
08-05-2009, 11:20 AM | #35 |
They also updated the Catle Link software again. It is now version 3.16
08-05-2009, 11:38 AM | #36 |
I wonder if they plan to fix the weak drag brake anytime soon |
08-05-2009, 11:48 AM | #37 |
08-05-2009, 12:02 PM | #38 | |
I finally bought a Tekin FXR because the Mamba Max drag brake is so weak with a brushed motor. The Mamba Max has such smoother start up and low end throttle control over the Tekin. Common Castle, fix the drag brake because I love all my Castle Creation products. | |
08-05-2009, 12:44 PM | #39 |
08-05-2009, 01:02 PM | #40 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
