03-12-2009, 05:54 AM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| Sidewinder issues!!!!
I just purchased a sidewinder from tcs and cannot get the drag brake to work! I programmed it on a castle link and callibrated the tx/rx and all that. I tryed reprogramming it and everything and nothing. I e-mailed casltle but still wanted to post to see if anyone has had this problem. Im running a 6-cell nimh with a losi 2.4ghz radio and a venom 55t motor. pretty standard stuff.
03-12-2009, 06:53 AM | #2 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
what settings are you using on castle link? did you set it up for brushed mode? they come stock in brushless mode.
03-12-2009, 03:33 PM | #3 |
Yah its set for brushed mode and NOT the high power bush. Its set 100% throttle power, 100% brake power, 100%drag brake power, and 100% reverse throttle power. Didnt mess with with the punch control or any of that stuff. And I made sure to set the voltage cut off off because Im running nimh. I was thinking it might be my trans mitter but everything callibrated good. Im stumpped. :-(
03-12-2009, 05:03 PM | #4 | |
03-13-2009, 05:10 AM | #5 |
| I know in working on that issue, but there are other trucks with the same esc and motor combo and have no problems. I dunno In still waiting on a reply from the big guys at castle to see whats up. |
03-13-2009, 05:13 AM | #6 |
Does it act the same both forward and reverse? Do you have drag with either direction?
03-13-2009, 06:34 AM | #7 |
It works perfect for forward throttle and reverse throttle its just when I let go of the trigger and it goes to the neutural position the drag brake never engages. there is none.
03-13-2009, 06:38 AM | #8 |
Yeah, I meant is there a difference in the drag brake when you are ascending or descending an obstacle? Does the drag brake work in either of those situations?
03-13-2009, 08:20 AM | #9 |
RCC Addict Join Date: Mar 2008 Location: SSF
If you have more brake in one direction than the other I'd say adjust your throttle trim.
03-13-2009, 08:21 AM | #10 |
03-13-2009, 08:51 AM | #11 |
Rock Crawler Join Date: Oct 2008 Location: Florida
I am running the mamba max with a integy 35 and am running into the same situation. I sent it back to castle and they replaced it and still the same situation. I then put softer brushes and stiffer springs and that helped a little. So what im trying to say is that I think Tanis is right its the motor. Lesson learned, I will be upgrading the motor to a holmes handwound will see if that helps. The only thing troubling me is that my friend runs the FXR with the same integy motor and has a awsome drag break. But Correct me if Im wrong from what I have read and searched the FXR has more of a hold brake different from the mamba or sidewinder. Either way the holmes motors are excelent from what I have seen and read so it is worth the upgrade because I do love how smooth the mamba is at low speed.
03-13-2009, 09:06 AM | #12 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
Post pic of what your setting are using the new download from cc, If you changed your throttle curve and brake curve this will also affect the drag. the new download will allow you to do this so we can see what the curves are set to.
03-13-2009, 10:57 AM | #13 | |
The Castle brakes are looser then the Tekins. Also poor or failing brushes lose drag brakes. A timed motor will give you better drag in one direction than the other also. Lathe motors are typically set at zero timing. | |
03-13-2009, 11:48 AM | #14 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
Like everyone has stated, the sidewinders brake is dependent on the quality of the motor you have. IF you are coming from a rooster crawler with the stop brake, you are comparing 2 different animals. I personally like the drag brake on the castle stuff, when you let off the throttle, you have a gentle roll. Not a sudden stop that will flip you on a downhill. With a nice soft reverse on the controller, it will stop and hold. I have integy 45t in mine and it has a weak brake. I had Rubbaneck redo that motor, trued the com, new brushes and springs and that thing is a totally different motor. No complaints now!! I have no experience with the Tekin esc's, but I have heard their drag brake is stronger than the castle stuff.
03-13-2009, 12:07 PM | #15 |
| If that is the case and there are others running the same thing and theirs is night and day difference to yours, it could also be your throttle trim not set at total neutral, besides the motor.
03-13-2009, 12:17 PM | #16 |
03-13-2009, 12:23 PM | #17 |
03-13-2009, 12:40 PM | #18 |
| If it is not the throttle trim, my money is on the motor. I am not familiar with the venom motors, but I imagine he might have gotten one with bad brushes or weak springs. My integy motor is night and day after Rubba got done with rebuilding it.
03-13-2009, 02:19 PM | #19 |
I checked and the throttle trim is set at 0 but I dont know the condition of the motor. I just got into this at the beginning of the year so I havent had time to pick up a comm lathe yet. Ill look at getting into a new motor. The venom motor seems to perform well for the money but Im unsure of the brush/comm condition. Does any one have experience with outrunners? I am considering picking up a 1500-1700kv outrunner. Besides having more torque I was told that brushless are stronger with a drag brake versus a brushed motor. Is that true?
03-13-2009, 02:25 PM | #20 |
Rock Crawler Join Date: Apr 2008 Location: Wrightsville, PA
I just got a WarriorII motor because I was having the same issue with drag brake. I thought it would solve my problem since its a much better motor, but I can't see any improvement over the cheap integy 55t that I was running previously. I should mention that I'm only referring to the drag brake issue. The motor has awesome power compared to the integy.
