10-04-2005, 06:29 PM | #1 |
Pebble Pounder Join Date: May 2005 Location: Nor Cal
| can i use this radio
can i use this radio and the included servo to crawl with? http://www2.towerhobbies.com/cgi-bin...I=LXEDP1**&P=7 |
10-04-2005, 07:05 PM | #2 |
Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
Looks like a nice radio might even wana consider a Traxxas Tq3 you can fin em on the bay for less then $30.00 Or you can get an Air Frequency Radio and get all the airplane guy pissed off for some reason they dont like when ppl say they are using those radios for crawling lol something about UFO droping from the sky |
10-04-2005, 07:06 PM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
that'll work if you have no intension of wanting the use of a 3rd channel for independent rear steer.for the same price (minus servo)which you'll want a higher torque servo any way.unless this is for a stock tlt which stock standard servos can handle.check this out http://www.thecrawlerstore.com/ |
10-04-2005, 07:08 PM | #4 | |
10-04-2005, 07:10 PM | #5 |
well its says that is comes with a high tourque servo as well or is it not good enough?
10-04-2005, 07:18 PM | #6 | |
Pebble Pounder Join Date: Aug 2005 Location: Stockdale, PA
10-04-2005, 07:21 PM | #7 |
so i wouldn't have to go out an buy a higher touque servo right?
10-04-2005, 07:35 PM | #8 | |
10-04-2005, 07:55 PM | #9 |
well what radio system could i buy that comes with a desent servo and i could crawl with?
10-04-2005, 08:22 PM | #10 |
Rock Crawler Join Date: May 2005 Location: omaha
Don't let a servo determine what radio you buy. Find a radio that is comfy in your hand and is balanced well (you will thank me for that after an hour of crawling), and is going to work with what you are doing. For crawling AM is not that bad. You are close to the truck so you most likely not have a problem. Even if you aren't going for rear steer right away, try to find a 3 channel. It will be a lot nicer later, you won't have to buy another radio, just another reciever for that second truck. As far as servos, look around this sight. All the info you will ever want is here. Try to get at least 120 oz. at 6.0v, get metal gears, and don't worry about speed. Buying a radio because of the servo will only serve to disappoint you. You won't like the radio that much and in crawling you are going to kill the servos in time. Look at them as two seperate purchases, like the motor and the speed control. |
10-04-2005, 08:43 PM | #11 |
alright, thanks for the advice man
